Scooner
    14
Everything posted by Scooner
  1. You can use the same thing, just a shorter one.
  2. I used a flex hose with built in spring for the bottom hose and it's worked great so far, i got it from advance auto.
  3. I also found this little gem, the bed has zero rust in it. In total i have found 7 Brats this week! 4-First Gen 3-Second Gens I'm pretty excited for what the future holds...
  4. I am REALLY hoping i can start a build thread on rescuing this 1980 Brat found behind a house here in Cheyenne. Me and the owner are in the process of getting a title. Its in really good shape.
  5. Dang, it didn't hurt to push a drill through the roof to mount those lights? Ow
  6. Looks great! I love those wheels, and basket and fresh EJ! How has it been running for you?
  7. I don't think i've ever heard of someone refer to a motor as yummy before haha. That's great.
  8. I had a badly cracked knock sensor on my engine as well and replaced it with a new one, you have to be careful when you reinstall the new one so the connector kind of points a certain way, if you dont you can break the new sensor and it won't seat well. Definitely look it up on here for some images.
  9. G, we found a bad fuel pump relay at first. We replaced it with a spare i had and now it clicks on like it should to prime the line. We also checked the starter signal wire and that was good, next was the coolant temp sensor and that was also good. We are definitely leaning heavily towards a leaky injector,dude has already went to the junkyard and snagged new, well other ones and fuel rails. We will replace all O rings with new and check that.
  10. Hey Mitch, do you have the harness still strung outside of the car, or do you have it all installed? How is you ignitor (igniter?) wiring looking? Also, where did you mount it at?
  11. Another good place to post this question would be in the new gen forum 1990 and newer, post the year of the swapped motor, what it is yada yada and the problem. Those guys deal with EJ22s alot and they are pretty helpful as far as i've seen. Cheers!
  12. ...crickets. ha. After looking at that thing and thinking about it i really do think it is a leaky injector or torn O-ring etc. Get you some new O-rings and put them new suckers in. I can't wait to hear what happens, especially after you told me about the truck incident and what happened to the one injector on that one fateful day...
  13. Just had a thought having to do with the IAC, on my first swap i did, i also ran all of my own wires to the sensors (which was ridiculous) Either way when i ran the wires i criss crossed the two signal wires to it and it wouldn't run. After switching those two wires it ran! Maybe there's a chance you have them backwards?
  14. I bet you guys are getting busy with the film coming up, i can't wait to hear more, what an adventure. A sweaty, man meat mission for adventure! Nothing better than an american road trip with your bros.
  15. That's good to know, i will have to go out and check oyt my wiring. I can tell you for certain that i do not have the vehicle speed sensor or neutral switch hooked up and now i am very curious as to what will happen if i do. Gloyale, would you mind setting us up with a link here to your write up on the EA to EJ swap? That would be super helpful, you have to remember that most of us who attempt this swap go off of numbchux write up which don't get me wrong it is great for the basics but alot of the detail in the neutral switch, vss, etc would be super helpful bud! Thanks!
  16. No, on the back of the starter there is a fat black/red wire, like 14 gauge that has a plug that slides into the starter. Maybe, yours doesn't have that wire? Hmm
  17. Yeah and as a matter of fact when i was out there i noticed the wire is a fat black with red trace that i spliced into. It kills me that you are so far away bro, if you were close i'd be over there helping you out and help make sense of the whole thing, and also give you loads of shielded wire i have left over!
  18. Is it a digital one? If so you can use the continuity setting to find exactly where those wires originate from the motor. That or use can use the ohm setting bud.
  19. Nice fan bro, did you get it off of amazon? Is it an 8"? Also, how are you going to wire it in? Since i live in Antartica where its freezing most of the time i wired both of my fans into two seperate switches. None come on automatically, just have to remember to turn it on but that's not hard to do!
  20. Im out herr looking at my engine and while i can't help you with the extra tps plug, i can tell you that at the tps plug that goes into the tps there are only 4 wires, a brown, black, red, and white. While i'm here i mine as well tell you that off of one of the square plugs coming from the engine harness there is a white with green trace wire, that is the temp gauge wire, (the one i mentioned about using the 270 ohm resistor) and another wire, a green with white trace. That one is the fuel pressure wire. If your donor was like mine there was no pressure gauge, just a light. Do what you want with that wire. I forgot to ask but i assumed you have a electrical meter so you can find where wires go right?
  21. I wish i could my man, but i went agains't the unbreakable laws of EA to EJ swapping and ran my own 6 conductor wire from the ecu to the TPS for that. So i can honestly say nothing about that plug brother haha.
