About snowscooby
- Birthday 02/08/1991
Contact Methods
AIM
baronrabbit
Location
Bellingham
Occupation
Full time Student
Biography
I go to school at WWU
Vehicles
97 Imp, 00 2.5rs, 08 OBS
snowscooby's Achievements
Advanced Member (3/11)
0
Hi all, I am working on a EJ25 DOHC full rebuild project and was wondering if someone could direct me to an appropriate thread or shed some light on my situation. Here is the problem: Part of the project involved getting a cam regrind from Delta cams. This went fine, but the engine uses hydraulic lifters not the manual rocker arm assembly. So my question is do the hydraulic lifters need some sort of shim adjustment before we reinstall the cams, or will they self adjust because they are hydraulic? I know the hydraulic lifters are self adjusting, but I don't know if they are to the extent of the regrind. The cam profile is one where they weld extra material on and then grind it down so the cam lobe is slightly larger than before. Thanks!
02 Impreza OBS that is having some interesting intermittent issues. Automatic with about 75,000 miles Symptoms Under acceleration the car lacks power and acts like its going to die. Shifts erratically. When you accelerate a little it will drop a gear and nearly redline, and sometimes it won't down shift when it should and bog down. Seems to make a slight popping sound, sort of like popcorn. It has an intermittent CEL, I haven't been able to pull a code from it because it doesn't usually come on and its my friends car. I was thinking some sort of faulty sensor? Any ideas?
Ran into problems on Monday with the input shaft teardown. Apparently there is a specific tool to pull the 5th gear off, which we didn't have and the dealer broke all of theirs. The dealer said to pull on the bearing flange below 5th gear. This resulted in shattering pieces off the flange. We then tried a bearing separator pressing on the outer race of the bearing. This resulted in fracturing the entire outer race. We did however move the bearing enough to create enough room to slip a separator under the 5th gear. We were able to remove it and the woodruff key locking it in place without any other problems. If you are trying this yourself and want to save your bearing/ be a lot safer you should pursue a tool to remove the 5th gear separately.
Pulled the center diff out of the transaxle, will probably break that down tomorrow and inspect all of the teeth ect. So far everything looks good. A good trick (if you would call it a trick) we found for getting the center diff casing off was to take off the top plate and try and tap it off from the inside rather than trying to go from the outside you damage the aluminum edge to easily where the different housings come together. And there probably is some truth the to brat seats and the founder ledgend. There were a couple big subaru guys who were professors in the VRI (I think there still is one). Some of the stuff they have going on in there is pretty amazing.
CV clunk
snowscooby replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
My car has been having backlash issues as well, and since I am rebuilding my transaxle in the next couple weeks I will check out the front diff and see if there is anything that could be causing it. -
There may be nothing wrong with it, but when it was pulled it was making some humming noises, it jingles in 4th gear, and some of the gears seem like they could shift easier. Since I got to wwu and am in their vehicle design program I am able to access the entire vehicle lab. One of the projects for my class is to do a transmission teardown and rebuild, so instead of using one of theirs I am going to use mine and hopefully benefit from it. Knock on wood nothing is wrong in the transaxle, but if it is, then I will be able to correct it. Starting teardown tomorrow. Hopefully will get through the casings.
I am about to delve into a transmission rebuild project for my 97 impreza's 5MT. I am not sure what to expect when I get inside there, but was curious on where to get replacement parts if I need new synchros or really anything for that matter (besides the stealership). I will be rebuilding the entire drivetrain for a class (front and rear diffs, transmission) and will try and keep the thread updated if information from time to time.
welcome aboard!
CV clunk
I have had decent luck with our local NAPA auto parts store. Anything that is new should hold up better than a reman cv. If you shop around a bit you may find them as low as 50$.
