papalobster
Everything posted by papalobster
I guess I should clarify. I'm ok with the light being on. I'm also ok with whatever codes it may show. We don't have emission testing here, so that isn't an issue. My problem is the car is in limp mode, fairly powerless and uses lots of gas. I'm guessing it's not sensing a variation between the 2 O2 sensors and because of that triggered limp mode and is running from a base map for the 2.5. I have a small pocket code scanner and when I erase the codes they all come back in a 2 mile drive. I'm going to dig into it a bit more this weekend. I grabbed the knock sensor from the 2.5 last night, but didn't have time to swap it out yet. I also came across a brand new 3 wire O2 sensor in the garage last night, so I'll just screw that one in and see if it clears the O2 sensor code.
Used the knock sensor that came with the EJ22, I can swap the 2.5 one in though (the connector is fine). Double checked the O2 sensor pins already, but didn't check the 3 big connectors all that closely. I'll do those checks and write down the Code #'s I'm not concerned withthe EGR code, just throwing it in there for reference. That won't put me in limp mode!
I followed the wisdom of the board, searched, researched and studied. I swapped out my problematic EJ25 in my 98 Legacy GT for an EJ22 out of a 97 Legacy wagon. Both cars are 5 speeds. Now when running, I get codes telling me both O2 sensor heaters aren't working, the knock sensor is throwing a code, and no EGR. Everything is connected as it should be. No vacuum lines are missing or disconnected. Was there something I missed during the swap?
Nobody wanted to buy my Legacy wagon, so I picked up a junkyard 2.2 to throw in instead of trying to make the 2.5 work. The wagon is a 98 GT 5-sp, and the donor is a 97 wagon with a 5sp. Other than the lack of EGR. What else needs attention before I throw it in? And yeah, I searched. And I read. And all I could glean was the tensioner needs changing, but nobody really specifies why it needs changing. It Sucks really isn't a reason! I grabbed the Y-pipe too. What abotu accesories? Steering pump/alt/a/c compressor? The lines were all cut when they extracted the 2.2, but I have ALL the electronics, save for the alt.
I replaced the HG's in my 98 Lego GT, lined everything up, made sure it was right, fired it up. and get a ting, ting, ting sound of a valve tapping a piston. I pulled the covers off again, counted teeth, re-checked everything. Crap. The heads have been machined twice and were still within service limits. I went from the Fel-pro head gaskets that have blown on me twice now to the thinner single thickness Subaru gasket that everyone recommends. I'm frustrated, and a little angry. I wish I didn't like this car soo much, it would be easier to start it on fire and abandon it in a quarry somewhere.
It's a 98 Legacy wagon, 188k. Bought it with bad head gasket, changed the gaskets (in the car) about 3k miles later it spun a rod bearing:mad: Junkyard engine with 90k on it for $300, best change head gaskets (out of the car:) ) along with th eassociated machine work. Blew a gasket 5k later. This is an awful lot of head gasket changing for a winter beater. I've been using Fel-pro's as they have been warrantied, but figure I'll use factory gaskets this time around.
The guys at Car Quest warranty the gasket set and gaskets as well as the head bolts, so it takes the pain away a bit, but I'd like to do it once and not have to do the gaskets again....EVER! Can someone clue me in on the part number for the new and improved factory gaskets? Searching through 7,234,701 posts was proving futile.
Nuther WI fella
papalobster replied to papalobster's topic in Meet n' Greet. Your USMB Welcome Center
I have this fancy shmancy funnel thingy that takes place of the radiator cap. Holds like 2 qts. of coolant. Let er idle for 1/2 hour while it works the bubbles out. Let it cool completely, run er again. That block has lot's of bubble traps though. Clicky I'm usually runnin children around or tendin to the dirt bikes/rallys/off-roading in the summer for any bbq. But, tell ya what I'm gonna do. If the Legacy is still working come winter, I'll let you fellers know when we're out riding on Lake Winnebago. We tend to ride for a while, then afterwards burn some meat and have a few cool ones (no cooler needed) and take a few laps in the cars. I plow 2-3 mile road courses on the ice for bikes. Great fun an dmakes winter fun again. -
I need to make sure the car is going to reliably drive. If I get it sorted, and you still have teh tires I'll take them, but I don't want to stick tires on something that may end up going to the junkyard.
Nuther WI fella
Got it together last weekend and took it for a spin, doesn't overheat but I get an occasional gurgle through the heater core and I have a stumble just off idle. I'm pretty sure I have everything where it's supposed to go. I'm going to give it the once over and make sure all teh connections are tight and hoses are routed correctly. I have to "replace" the resonator too. At least things are happening in the summer when I don't mind wrenching so much! -
I'm doing some searching and reading but figured the fastest way is to ask out right. I have a 98 Legacy GT EJ25 5-speed trans. I get binding on occasion. Primarily, clutch pushed in, coasting to a stop after backing up with the wheels turned ie backing from my driveway into the street. Being a stick, I don't have the FWD fuse option. So the couple questions I have are 1 is this a clutch pack system or viscous coupling? And 2 what type of oil is the preferred oil? I have the car on a lift for the head gasket replacement, and wish to change the oil before hitting the road again and add anyadditives required to extend the life of the diff.
Nuther WI fella
Naw, the previous owner lets me use his shop (with lift!) to do the repairs. he not the beating the crap out of the car type. It was just time. I'm using Victor Reinz gaskets. Out of a total of 3 failures in the same car 2 sets were factory parts:brow: Reassembly starts today. Heads are milled, blocks is flat. Parts are stacked. I'm in Fond du lac. -
Just sayin hi, I have lots of reading to do. I picked up a 98 Legacy GT wagon with a 5 sp. late last year. The person I bought it from said the head gaskets were leaking, we changed em out with new t-belt, water pump seals and everything that might have or have not been work in the 176k miles. 1k miles later, rod #3 spun a bearing. Junkyard score 96 EJ25 auto engine. Swap all the new parts onto the New (97k mile) engine with new head gaskets and a swipe on the heads to clean the surface. 2.5k miles later, overheats, and I'm now in the middle of replacing gaskets and having everything machined flat again. So there's my saga. I still like the car, and the wife loves it. She keeps making me take the mini-van! Hopefully it'll back on the road in a week or so.
