FindingForester
Gender
Male
Location
Costa Mesa
Interests
Music, electronics, cycling, skiing, photography, history, mechanical stuff
Occupation
Audio Engineer
Vehicles
2005 Forester XS—70K+ mi.
FindingForester's Achievements
Advanced Member (3/11)
10
I discovered with my wife's Forester that some aftermarket rotors have a different profile than the originals. It didn't seem to affect the braking but it did cause some annoying noises when nearing a stop. I eventually had the original ones turned (one was quite warped) and put them back on, and the noise went away.
That seems to not be the case. With the same pads but with the original rotors back on the car, my wife reports that the noise is gone. I'd say it most likely has something to do with the aftermarket rotors having a different profile from the originals. I would repeat that the original rotors were cleaned up quite substantially (I gave them a naval jelly and wire brush treatment before I took them to be turned on a lathe).
Or more likely, with the pads. Since the noise wouldn't appear until after the car had been driven at least a few minutes with several applications of the brakes, it was probably related to thermal expansion of the steel rotors (coefficient of about 0.000011 to 0.000013 per C°), which would increase—though slightly—the diameter of both the raised portion and the narrow ring between it and the braking surface. Perhaps enough to scape against the edge of the brake pads. You can't really tell anything by the rust in this photo. The original rotors are cleaned up pretty thoroughly. They were very scaled, especially after sitting in my garage for a couple years. Both the original and aftermarket rotors develop visible rust markings on the braking surfaces even as the car sits overnight.
The rotor on the right is an aftermarket rotor that I had installed on my wife's 2005 Forester a couple years ago. On the left is one of the original rotors, after resurfacing at a local shop. You might be able to see in the photo that the aftermarket rotor has a raised area, about a half millimeter or so, just inside the braking surface. The original rotor is actually recessed slightly inside of the braking surface. That raised area apparently was just enough to cause a moaning, slightly grinding sound as the car came to a stop after a couple applications of the brakes. This noise was mystifying. Some friends suggested that the rotors were glazed, so I tried roughing up the rotor surfaces a bit a couple times with sandpaper. The noise came back. I disassembled the brakes and made sure everything was in place, no bent clips or anything. Nothing seemed amiss. Added some anti-seize lube to the backs of the pads. The noise came back again anyway. Finally in frustration I decided to replace the rotors with the originals. One of the original rotors had developed a significant warp (which is why I had decided originally to save time by replacing the rotors when I did the front brake job a couple years ago, instead of leaving the car jacked up for a few hours to have the rotors done) so I had them turned at a local shop to prepare them for reuse. When I compared the original and aftermarket rotors side by side, that raised area was a pretty obvious and visible difference. The original, resurfaced rotors are back on the car. So far, no noise. The lesson I learned is that just because an auto parts store lists an aftermarket product for a given year, make, and model, it might not actually be a good fit.
A poor electrical connection will do that. Considering the amount of current that an alternator is often called upon to produce, every connection has to be in great condition. For example, even a resistance of only 0.05Ω, which is too low to measure reliably with a convention ohmmeter, would dissipate 180 watts of power if the alternator is putting out 60 amperes, which it might be called on to do after starting the engine, with the lights on, etc. (Power = I^2 × R). That would be like having three 60-watt soldering irons applied to that single point, If the current output drops to 30 A, the dissipation would drop to 45 watts—still a sizeable amount of heat to develop in a single small point, and it would probably get quite hot to the touch. That's what causes connectors to melt and burn.
Yup, a wiper (not washer) refill. I'd been making the rounds at auto parts stores to no avail; the Trico, Anco, and Bosch books had no listing for either the blade or the refill. Thanks for the info and part number, Subie Gal. That's a reasonable price for an OEM blade. I'd done a search on subarugenuineparts.com yesterday and nothing came up, but sometimes searching by keywords can be quirky. The specific part number helps a lot!! I'll buy a couple extra to have on hand.
I haven't changed the plugs in a Sube but in my 1988 VW Golf, now with over 245000 miles, I ran my first set of Bosch platinums for well over 100000 miles. I just removed them every 25 to 30 thousand miles, and since they looked good I lightly brushed them, regapped them, put fresh anti-seize on the threads, and put them back in. I finally replaced them a couple years ago when I figured I'd taken the spark plug frugality thing far enough. But I never had a problem with them.
When the tank is low, try maybe 1/2 tank of reg and see if the car pings or knocks or runs like crap under acceleration. If it doesn't, you're most likely fine. If it does, then top off the tank with the higher octane. Both regular and premium gas have the same heat of combustion--that is, the same amount of energy per gallon. Higher octane gas is more resistant to preignition.
