Roopilot
About Roopilot
- Birthday 04/06/1949
Location
St. Paul
Vehicles
I Love My Subaru
Roopilot's Achievements
Member (2/11)
0
Borrow, buy, or rent a fuel pressure gauge. The fuel rail should have a fitting to screw it onto. All that I have run into look like a tire valve (schrader fitting). Just screw it on and run the fuel pump. I don't know the exact spec. but should probably pump up to around 35psi. It should also hold that pressure when the pump is turned off.
Axles were replaced due to occational clunking noise during turns. They didn't cure it by the way. The clunking noise is also worse when cold. I also replaced front wheel bearings. It is definitely a binding problem when cold. I have not done anything with the front differential. You think it's worth changing the differential oil? I remember when GM had an additive for posi rear ends that worked wonders. Is there a similar additive from Subaru? Is the duty C and clutch pack in differential fluid or in trans fluid? I suppose I'm putting of the inevitable. I don't want to spend the time pulling the engine / tranny assembly. I have to do it on the floor (no lift).
140K mi. I have put on all but 36K. Most torque bind posts say it occures when warm and goes away when cold. Mine goes away when warmed up. I commute 70 mi. to work. I start out in the morning with binding even moving straight. Once I get 3 - 4 miles it clears up. I tried the fuse. The light on the dash lights but the torque bind dosen't change. I read that if the light on the dash lights the duty C coil is ok. Is that correct. Can clutches stick? I changed 4 qt of trans fluid and added Sea Foam. If it was grooves as I have read somewhere It shouldn't go away warm. With the kind of miles I put on I'm willing to fix the problem but I'm not sure what to look for. Ideas?
I think the only things moving when you pump the throttle is the throttle plates and throttle position sensor. I'm not sure what bearing the throttle position sensor could have on starting. I would check fuel pressure for a leaking injector. It could cause flooding when warm. I would expect roughness immediatly after starting but then run fine.
1994 legacy SW, 2.2, 150,000 mi. I got on the board today because I've been having intermittent starting problems for 3 years. It was a couple time a year in the fall at +20. Worse now at below zero temps. Repair shops and dealers can't locate the problem because it starts once they have it in the shop. No codes. I'm pretty sure it is lack of spark. Plugs are wet after a no start. I hate throwing parts at it but I think i'm to that point. The cam sensor, coolant temp sensor, and coil pack have been replaced. The igniter was repalced with a junk yard unit. The crank sensor has not been replaced. Im looking for ideas. I don't trust it to get me home from work anymore.
Thanks, but why is it ok for 10 minutes. Ignition off / on resets it and up it goes again for another 10 minutes. Also I've had it remain up all day with the key off (setting not runnig).
I just bought a 27K milage Loyale SW with air suspension. The right rear drop after 10 minutes driving. Turn the car off and back on, it pump right back up for another ten minutes. The blinking light comes on when it falls. Does any one know what to look for?
