Everything posted by Setright
I speak Danish which is near enough. Before your man takes the Volvo up the hill, he stress that BOTH are automatic transmission and the are fitted with the exact same tyres. At the end he says "Why is this so? Because Volvo chose a cheap system." A rep from the the Danish importer actually shamed the Volvo too. Similar setup, he pulled a CARAVAN up a muddy hill, and the Volvo was able to follow - even though it spun the front wheels. So he upped the ante..drove half way up and stopped the Subaru, set off again without problems. Volvo got stuck....LOL !
The intake is the area below the windscreen and wipers. You can remove the entire plastic shroud and fit your own net there. I think they had these from the factory, but it may have rotted away. The side vents can be pulled out, the ones in the center of the dash cannot. If there are leaves stuck in there switch the fan to full blast, that'll press the leaves all the way up to the vent. You can pull them out with a pair of tweezers.
EJ18 Carb
Setright replied to waimaks's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Are you sure it's a fuel problem? Try adjusting the mixture. We used to detach the vacuum hose from the carb when we set the idle mixture. It's much easier with the hose off. Could be worth dismantling and clean the carb, before searching for a "new" one. -
Yes, have the torque wrench calibrated if you can. Also, whilst 100 ft/lbs isn't vicious over-torque, over tightening can also lead to lost wheels if you stress the studs to far! They'll snap suddenly under load. Remember that the wheel/hub undergoes thousands of heat cycles. (Of course the main reason for the low torque range is to protect the soft alloy wheels.)
I disagree. Worn pads cannot cause a low pedal, the fluid fills the brake lines to compensate. Worn brake shoes can cause extra pedal movement, if the automatic adjustment isn't working. You could remove the drums and give the adjustment mechanism a click or two more to push the shoes outward. The drum should fit snugly over the shoes, but not drag on them. Start there, then flush. Or flush anyway, since it's probably a while since the last time. Yes, DOT 4 is good in these systems. However, if there's DOT 3 in there now, you might want to continue using that, unless you want to bleed the system two or three times - if you have ABS. Flush, drive and brake hard enough to activate ABS. Flush, drive and brake hard enough.... This will ensure that you also replace the fluid in the ABS pump.
It's a bit hit-and-miss. Sometimes replacing the bolts will do, but look for cracks on the shield. If there are any, try to strap it down with "jubilee clips" - metal bands with screw locks. (No idea what they are called across the pond.) Welding can also be successful....get the car up on a lift and inspect.
Ultimately, those marks shouldn't be there. On the other hand, they will not compromise the crankcase integrity. What's the mileage? A bit of thrust bearing wear allowing this kind of contact is nothing to be ashamed of on a high mileage engine, like over 120k. The EJ engines are pretty tight in terms of length, so a small amount of thrust bearing wear will show up like this pretty soon.
