Everything posted by Setright
Setright replied to Subaru X's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Nice. If the roar begins to get on your nerves consider extending the pipe into the top of the fender cavity and placing the filter there. -
The Impreza "daddy" is the limited edition 22B - which is the old body style. That pumped out 350bhp from 2.2 litres, running 100 Octane. The new STi will be using the 2.5 litre engine. Currently as seen in the Forester it develops 211bhp running 95 Octane. If I may now stray into pure guesswork: The Original Impreza Turbo had 208bhp. The same engine when installed in the Forester had 177bhp. Based on that ratio the 2.5 liter Turbo installed in the coming Impreza will develop ca. 250bhp. The standard WRX to STi ratio, is currently 225bhp to 265bhp. Meaning that a new STi would run 295bhp. Mapping for 100 Octane would yield how much? On the gearbox thing, the 2004 model STi's have an oil pump in the gearbox! I reckon that Subaru have finally realise that their gearboxes need some improvements.
You could suck up as much fluid from the reservoir as possible and refill with fresh ATF Dexron II or III. Bleeding is quite simple, get the car on loose ground like gravel and swivel the steering wheel from one extreme to the other. Hold it in the extremes for a few seconds, where pump makes a louder noise as it recirculates the fluid. Hopefully any air will be purged too.
It's a deal breaker if the piston slap is still present when the engine is warmed up. My car slaps in the morning, and again if left off for over four-five hours. However, it disappears soon after the engine temp needle hits normal. IF the slap gets worse as the engine heats up, don't walk away, RUN away :-)
You'll be fine with Mobil's products. Don't let the mineral vs. synthetic debate scare you off. I like to run 5W-50 in my engine, but I do take it on tracks every now and then. Plus hunt the redline daily Replacing the tranny filter is probably a good idea. Stick with genuine parts - for the engine oil filter too.
Okay, the WRX has gotten heavier, but how can you describe the performance as dissappointing?? Sure it needs revs before the turbo comes on full song, but these days the transition is so smooth that the "kick" we used to get in the bad-old-days is gone. If you want Turbo kick, get a Porsche 911 Turbo. The 930 model from 1975. That engine has about 2 hp up to 3500rpm and then it suddenly dumps 200hp on you at 3501rpm
Lower viscosity ratings will improve shifting. I spoke to a tech at Castrol today because I was trying to find out if I could get some friction enhancing additive to help soothe the shift into third. Since that wasn't possible I asked about using a thicker oil, like 75W-140. The reply was "no, since that means the oil will take even longer to get out of the way and leave the synchro cones time to work". Conventional wisdom would otherwise lead me to believe that a thick oil would tend to have more drag and hence enable a better synchronization. He went on "well, the oil would stay between the cones and the thick film would provide fantasic lubrication". But no speed matching. So, I will be draining my much loved TAF-X in favour of some SMX-S. The ratings are 75W-90 and 75W-85. I'll drop back in when I have tried it out
As Loyale has pointed out: One tyre alone can't do the damage. The open diffs on the axles will absorb the difference. (Yes, yes, some models have LSD in the rear.) IF you have different sizes front to rear, you will run a high risk of damage. Even the manual center diff will be destroyed. Heating the oil causes it to expand and press the plates together, giving more or less torque transfer. OVERheating the oil with different axle speeds will shear the oil molecules and thin it out. In the end it won't expand as much, or be able to transfer the torque.
