Everything posted by Setright
GC is the chassis code for the first generation Impreza sedan. BC is the...................................................Legacy sedan. I think you should look for struts and springs from a GC (or GF station car) Impreza if you wanna keep the strut swap easy. Legacy springs will not be matched for the lower weight of the Impreza, and handling/ride might be ackward.
help!!!!
Setright replied to 98legacywv's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
It's a headgasket failure. For sure. And as MTsmiths says: How was the car towed? -
The factory manual says to remove the two engine mount bolts and raise the engine. It also says to remove the exhaust manifolds, but if you can get clearance without doing this, it will save you a lot of hassle trying to seal the manifolds later. Be aware that there is a long tube that sticks into the pan, and that the pan has a lot of internal plates, meaning you need to wiggle the pan forward, down and out.
Wheel Offset?
Setright replied to blitz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
To clarify my point: The offset is in relation to the CENTER of the rim. Nevermind the absolute width, it's the offset that denotes the length of the lever that "carries" wheel forces into the hub. -
Wheel Offset?
I disagree with Scott. -
Jacek, more rear inside wear can result from two things: Too much toe-in, and the tyre drags. This usually gives small but visible ridges on the tread blocks. Too much negative camber: Stock at no load is -1.0 in the rear. Heavy loads will lower the rear and increase inner wear. Wear will be smooth. Front outer wear can also be a toe problem, but it often stems from compensating for wrong rear toe! The manual I had for my 1990 Legacy also stated the outer front wear could be caused by "excessive speed in turns". A small amount of negavtive camber will compensate nicely for this.
Antilock Noise
Setright replied to rem14's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Whirring/buzzing is normal. You can sometimes hear it at start-up in the moring, as the system runs a self-diagnostic test. Mine also keeps whirring for a short while after activation on ice. It also starts whirring as soon as I the touch pedal afterwards, I suppose in preparation for more "hard work". There is some sort of adaptive programming in there, and if the system decides the car is on really slippery stuff it doesn't wait around.
