Everything posted by Setright
Spoke to a chemist friend of mine and he immediately suggested that the coolant must have changed PH value, and therefore changed color. PANIC!!! Is my cooling system full of acid? I gave him samples of unused mix and some of the mix from my engine. New PH 8.3 Used PH 7.7 So, it's a sure sign that the coolant is "wearing out". By the way, checking the mileage in my logbook, it's actually 6500 miles since I replace the coolant, or 3½ months. Panic is over, but I am gonna change the coolant soon, it makes me worry that the color is fading. By the way, adjusting the PH back up on the used coolant did NOT bring back the color, so the dye is gone forever.
I have used Varta maintenance free. They don't seem "fragile", and there is no discernable drop in cold morning current - based on starting. Optima is made by Banner BAtteries, and I had a bad experienc with their maint free batts. The posts are too small a diameter, my earth couldn't get a tight fit. So I returned it.
Dang it, it really does sound like a bad t-stat. I know its a pain to open the cooling system again, but I would recommend you start by replacing the t-stat. OR, block off part of the radiator with a piece of cardboard to avoid overcooling. Which brings to mind: Is you radiator fan running? Like all the time?
All in all, it sounds like Subaru haven't lost all their old charm. My Impreza was over two seconds starting up on a frosty morning recently. What does the ECU do? Determine temp? Oil pressure? Time the engine has stood still? Before sending the OK signal to the injectors? What a shame that a really cold start is accompanied by piston slap ;-)
Yeah, I just checked inside the rad, and that is losing color too. Wierd. You would think Castrol could do better. No additives. I am not an additive kinda guy, I trust the chemists to make a good product from the outset. The only thing I ever add to anything is RedeX injector cleaner to my gasoline.
Is it a European import? We have had a Forester XT, with a "detuned" Impreza WRX engine giving 177bhp for quite some time. Including the old shape. Not sure what was offered stateside, though. But I must agree: Pop the hood. OR, just leave it closed, because it will have a scoop for the top mounted intercooler if it has a turbocharger.
Hi everyone! During a rountine fluid check I discovered that the coolant in my overflow tank is almost completey clear. It's 50% Castrol antifreeze and 50% pure water. It was very blue when I poured it all in about 3000 miles ago. I haven't opened the rad to check the colour in there, it's too dark outside right now. The coolant level is perfect, it's the colour that has faded. Shell's 50/50 mix which I used to use never did this. What's up with that?
friendly, it very much depends. What's the corner's radius? What gear are you in? What tyre pressures are you running? Is it wet? "Traction Control" was actually invented to counter the otherwise sound advice you are giving. Too many drivers think they will have an accident if they go through a corner off the throttle. So much depends on how you entered the corner. There are no rules of thumb. Except that a Subaru will give you time to think about it before it spins you round!
