Everything posted by Setright
Quote from emisions testing:¨ Some Subaru AWD owners have contacted Subaru of America, Inc. and their authorized Subaru dealers seeking warranty reimbursement for transmission damage caused by two-wheel dynamometer testing. These owners reported no driveability problems prior to state-enhanced emission testing, but sought repair for driveability symptoms (vibrations, noise on turns, etc.) within 100 miles after the improperly performed two-wheel dynamometer test. The Subaru Emissions Defect and Performance Warranties, which cover defects in your vehicle's materials and workmanship, do not cover damage resulting from improper testing
The towing company better foot the bill. Did you tell them it was AWD? Most experienced tow truck drivers know that Subaru's are often AWD/4WD, and usually ask you. The silicone oil in the center diff has been overheated and therefore lost it's viscosity. The damage can take a while to show up. Six weeks is within that while. The main problem is discovering the damage, which can be hard during normal driving. You need to race away from standstill in the rain, and get lots of front wheelspin to find out. The Subaru main website has a guide for towing and the related problems.
You should be able to tell by the headlights - unless they have been replaced. The parking lights are built in behind the same glass as the main lights. Looks like this: http://www.geocities.com/vik2r/Sube/ff75close.jpg Euro and Asian indicators only flash for turning, otherwise they are off. Parking lights have to be white.
Sorry man, the transmission is still gonna be screwed. All four wheels need to rotate together, with only a few percent speed difference front-to-rear, or the Limited Slip center diff will die a premature death. De-clutching only release the engine from the gearbox, not the gearbox from the wheels. Try running 10% higher pressure in your front tyres, entering a ninety-degree street corner at 40mph in second gear, on the gas. Step off the gas aprubtly and feel the tail slide, without smashing your center diff! Alternatively, try approaching the same corner at 50mph, stand on the brakes hard as you turn the steering wheels and then planting the throttle in the carpet. If you want oversteer in general, fit a harder rear sway bar or stiffer springs in the rear only.
Who1981 describes the method for taking up slack in the handbrake cable. This will work, to some extent. You checked the pads? The handbrake uses internal shoes! Yep, those discs are hiding a small drum brake inside them. The shoes are probably worn. The shoe clearance can also be adjusted through the drum backplate. Locking one set of wheels on permanent four-wheel-drive cars is not a good idea. Your transmission suffers.
Pedal creak. It's probably coming from where the throw-out bearing pushes on the clutch spring fingers. The solution is to disconnect the clutch linkage - after removing the air intake - and slide the throw-out bearing back a little. It is then possible to apply a small amount of high-temp grease on the fingers using a long paintbrush. Possible, but difficult. You are trying to get a brush through a hole already crammed with a clutch release fork, flexible rubber seal, and at the same time get some light and a line-of-sight down there. But it does cure the creak!
