thefingD
About thefingD
- Birthday 02/01/1988
Location
Bellingham
Interests
everything
Occupation
CNA
Vehicles
I Love My Subaru
thefingD's Achievements
Member (2/11)
0
I forgot to mention, I just swapped the engine and thats when the problem started. So Im thinking its something on the new engine thats bad. before it ran ok just the previous engine had 300k on it and it leaked oil like crazy. And instead of buying all new seals I figured Id just drop a different engine in. It could be the cats... I found the entire exhaust in a bush out at my dads junkyard 2 years ago(I know that sounds bad, but it looked good- had no rust etc). It worked great up until the engine got swapped out, so Im thinking its gotta do with something new that I put in. I replaced on the new engine: power steering alternator spark plugs spark plug wires wireing harness water pump timing belt fuel injectors (these parts wernt new except timing and spark plugs, they came off the old engine, but I atleast knew they worked.) Which leads me to believe its gotta be one of the sensors on the engine that is failing... Or fuel pump or something. Feels like the engine isnt getting enough consistant gas going up hills.
Ok so I have a subaru legacy, 1990, "L", with 2.2L multipoint fuel injection and manual transmission. Runs fine all around town, starts right up, there is no wiggle or strange sounds coming from the engine, just when I go up hills it start to loose power and jerk on me a little. But as long as I dont go up hill it does fine. Excellerates up on the freeway fine, etc. Sometimes when Im going 70 in 5th I get the slightest shutter. But very faint. When I turned around on the hill my idle went down a bit but came back fairly fast. Im currently getting these codes off the ECU. 32- oxygen sensor or circuit 35- purge control selenoid or circuit 41- air/fuel adaptive control 22- knock sensor 24- air control valve or circuit They wont clear no matter what I do so Im guessing they're phantom codes. Also Ive had this car for 3 years and the check engine light has been on ever since I got it. From what Ive researched it sounds like a bad knock sensor? Is there a way to test a knock sensor with a meter?
Things is that there are tons of em up here. Which means most the junk yards and "pick a part shops" are fairly well sifted through. There freaking too popular up here. Only car Ive ever owned that Ive parked in a grocerie store parking lot and there would be 3 or 4 white subarus just like mine all in a row.
yea just money is tight right now so if I can get by with a 3 dollar fix Id be down. I think Im going to try it, really what do I got to lose. I dont think its corrosion on the plug... The plug looks all tore up like someone tried to unplug it but didnt know what they were doing. Im thinking the plug got the wrong end of a screw driver and now its all gapped out... just my theory.
Right next to the battery there are 3 main plugs that come off the wireing harness. They then direct themselves into the fuse box. 2 of the are almost square (2" x 2"1/4 or so) and the other is smaller (2" x 1"). I was going to splice through that plug. It wont make things easy when I want to disconnect it because id have to remove the heat shrink and 8 little plugs... apposed to 1 large plug. But... I was going to use something like this, and then cover each wire in heat shrink. Maybe add a dab of solder to it for extra hold and conductuity.
Im fairly possitive now that it is the engines wireing harness. I took the car around the block a few times and when I got back I jiggled the wires and it killed the engine. When the engine was off I kept jiggling and it was turning my radiator fans on and off. Also while it was doing that it was making a loud clicking noise, which is the same I heard while it was going all hay wire. If I cant find a cheap wireing harness, do you think I could get by with just splicing the wires together? Solder or butt splice?
Ok so I disconnected the alternator, and there was no change in the engine. I plugged the two black wires together and I got these codes. 32 Oxygen Sensor or Circuit 35 Purge Control Solenoid or Circuit 41 Air/Fuel Adaptive Control 22 Knock Sensor or Circuit 24 Air Control Valve or Circuit What do you guys think? Considering I allready had a little issue with the wireing harness could all of his these things be running on one plug or something? Also the engine sat for about a year before the swap... could all of these sensors be bad?
my dad owns a junk yard and he had a legacy that was a 91 that was hit in the back. It had only 100k on it and a perfect interior... all around the engine there were markings where the owner noted oil changes and it seemed loved. I never really started it until the swap. It drove great around town until I noticed it wasnt going up hills well. Which led to figuring it had clogged fuel injectors In short I had no idea that the engine is good. I drove it for a week before I noticed it wasnt going up this crazy steep hill. After I swapped the injectors off the old engine (Old engine leaked tons of oil and its seals sucked so this engine was easier than changing the headgaskets) so I knew they worked. I drove hard for about 5 miles, I was really testing it taking up to 60 and driving 20 in third to hear if it would stall. Sounded great until about 5 miles in it was like I hit the Bermuda triangle and everything went to hell. I think it has to do with the wiring harness. The new engine has a slightly different wiring harness. On the drivers side of my car behind the battery there are 3 fat (2"x1" or so) plugs. The new engines harness only had 2 there. I swapped the harness off my old engine and it had everything I needed to complete all the connections. When I first put it in I would take out the key and all the dash lights would stay on, but dimmer. And when I turned the key it wouldnt start. I pushed on the plugs and it fixed the problems.
