Everything posted by Strakes
Carfax info
Strakes replied to edrach's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
check your email! -
Carfax?
Strakes replied to rweddy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Please check your emails! -
Update: We are really happy that our shop found a low mileage used transmission. It's amazing how nice this car drives now. It drives like it's new. The transmission is silky smooth. It gets about 2 mpg better. So maybe the old tranny was "dragging" or wearing a clutch that finally broke apart? Being a bit nuts, I have changed the fluid 3 different times since it was installed to get most of the old fluid out...the shop I had used had also serviced it before handing it over to us. Now the plan is to change the fluid every 10000 miles. Everything aft of the flywheel is newer (newer starter, differential, etc). Anyway, the shop removed the old transmission pan for giggles. According to them there were many large chunks of metal laying around up in the screen area. Guys, thanks again for all your help!
Max pressure when cold will make the tire pop? What? First of all, it's okay to put the pressure up a little. I am happy with 4 psi more than stated on the door but never over the max stated pressure of the tire. There are a lot of opinions on tire pressure. My previous Volvos had 2 pressures on the fuel door, one soft ride at about 29 PSI and one economy at 36 PSI. I liked economy the best for handling and fuel economy. If you like the soft ride, stick with the door jamb pressure. If you want more, incrementally raise the pressure in all your tires until you're satisfied with the ride and handling. If you go too far, you may lose traction in the wet. Second, you can put the pressure up to max pressure when cold...then drive all day long. You're tire won't blow up. That's why it states "max pressure cold" on the sidewall. This is calculated by the tire manufacturer with allowance for the air pressure to increase when hot.
Carfax?
Sent one to abeauch & Ozified, should be in your emails soon. -
Um, have you tried taking some oil out? I have had success with a $4 hand pump that goes onto gear oil bottles, but using it with the suction-hose stuffed into the dipstick hole and pumping some out to get the level right. And if this doesn't work, search nasioc for Uncle Scotty's Cocktail....it's very nice.
Carfax?
gwar28: check your email. Just forwarded a report to ya! -
Carfax?
Sent a report to your email...should be there in a few minutes. -
My 2002 does this when I go to certain gas stations. I don't know why. It hesitates and misses until the computer figures out what's going on. I think it happens when you switch grades, or brands of gas...but it happens so rarely now because I've stuck with the same gas station. I know that certain stations here have ethanol added, and others dont. Maybe its the particular fuel density because of the temperature or pressure oe the addition of ethanol or other additives. I know that fuel's density can change with temp, and a sudden change might throw off something? These are just wild a** guesses. If mine hesitates, it goes away after a couple miles.
The mirror isn't bent down is it? No other things causing it to allow air in? I had an annoying whistle that was fixed by very carefully pulling up on the mirror slightly to bend the mirror mount back to where the door properly sealed. How much is a new seal? If it's not too expensive, just replace it. If it's beyond your budget this is my ghetto method: Get black silicone rtv and thick plastic sheeting (I used zip-lock bags cut to size). Liberally spread the silicone on the problem seal. Put one layer of plastic on the sticky silicone. Shut the door. Wait overnight, open the door, and carefully pull off the plastic. Sprinkle a little bit of talcum powder on the silicone and drive it to see if you fixed it. This method lets the silicone mold to the irregular shape of the door and frame. It worked on an old Volvo of mine and if you don't go nuts with the silicone, the fix is almost invisible.
Thank you for all your help. This board is awesome. I tried adjusting the bands according to the haynes manual and nothing changed. I have given up and now I am trying to source a used transmission for it. If I do that, we will be buying a lower mileage used car or minivan for my wife and selling the 93. My wife loves that 93 so much that she's actually quite bummed. She said that she's never been really attached to a car like this before. Funny how an car can get into our emotions...I can relate to her, I've had an attachment like that to a couple of my previous cars.
Great to hear of a simple remedy. Glad it worked out. I always replace my headlights or brake lights or whatever pairs there are together. My thinking is that the pairs of bulbs all have about the same useful life, were installed new at the factory, used about the same amount, and therefore, if one fails the other matched pair is about to go soon.
