I am new to Subarus, bought an 82 Brat GL 4x4 a few months ago then bought another 82 GL last week for parts. (Found both on Craigslist). Both run well, but need some repairs.
White one: Has 180k miles, needs AC recharged/fixed, door handle on pass side, dashboard is severely cracked, dent in DS door right on the door handle, exhaust bolt holes are stripped on pass side.
Questions: How far in can I drill to retap the exhaust bolt holes? (I assume I will need to get a special bottoming tap.) Has anyone stripped and recovered a dash? I tried charging AC with no success, is there anything I should know or look for before I take it in to have it evac-ed and recharged? Compressor seems to work well and I can see liquid and bubbles flowing through the small glass examination port.
Red One: has 90k miles, left rear wheel trailing arm bent causing bottom of wheel to be bent in a few degrees, came with replacement hood and left front fender to replace existing damaged ones, needs new left tail light assembly.
Questions: What is best way to straighten rear wheel/trailing arm? (I have a hydraulic ram and chains.) What other damage should I look for in the drive train that could have resulted from the wheel damage? Will a tail light from an early 80s Loyale fit in the Brat?
Thanks in advance for any advice/help. Expecting many years of fun driving.
Rick
