JaapH
Contact Methods
Website URL
http://
Location
The Hague in The Netherlands
Interests
Photgraphy, traveling, cars
Biography
I have a US imported 96 Outback which is different form the Dutch models. So that's why I whatch this board. Do all the maintenance myself, when the weather is fine.
JaapH's Achievements
Advanced Member (3/11)
10
I used a thin brush and white spirit (others use brake disk cleaner). I gently cleaned the wire on the inside. Didn't see any dirt but it seemed to solve the problem. I know the MAF is very delicate, so be carefull with this procedure. Prob. the problem will return, but up to now it helped me. Jaap 96 OBK (The Netherlands)
Knock sensor
JaapH replied to mattocs's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
No coolend will come out. Make sure the new sensor is positioned correct (watch where the wire comes out from the sensor, that spot should not touch the engine) otherwise you crack it when you tighten the bolt. -
All cars in Europe from a certain date onward, have to have rearfoglights. You can have one (left side) or on both sides. Here in the Netherlands you are only allowed to use them in thick fog because they do (when using 2) suggest you are hitting the brakes or you can even blind the drives behind the car ( in rain conditions very bad). Al Subaru models ( I know from 1997 onwards) have rearfoglights. The older foresters have sepparate lights in the rear bumper.
I would advice you to purchase the struts in the US. Prices of OEM struts are 3 to 4 times higher in the Netherlands than in the US. Hal's parts (halcoots@skybest.com) sends them to Europe and gives good deals. Make sure they use surface mail and you will have to pay 20-24% import tax for bringing it in. I have a lot of experience with them. Nice people. But in your case you have to know which part you want (numbers!) for they only have info on US cars and there are a lot of differences between European (made in Japan)and US cars (made in the US) or modelyears. Tru the dutch Subaru board (subaruclu.nl) They are 99% impreza. They can help you with numbers/manuals. Goodluck Jaap The Netherlands
Legacy777 I tried the spraying with water. No indication. However I skipped your remark on the MAF. Its the vortex type airflow with a hot wire. Could that cause an instant engine cut out? Is cleaning an option? They are rather expensive. Also was thinking of the engine temp sensor, although doesn't realy make sence as the car is at working temp. The vapour lock mentioned earlier I would expect at high outside temp. Any advice on the MAF-sensor? Thanks jaaph The Netherlands
My wife drives a 96 2,5 Outback (automatic) phase one 1st HG. She has encountered a problem with the engine suddenly cutting out while driving. This is the scene: It happens only on cold (no ice) foggy mornings with a lot of damp (typical Dutch winter). She drives about 2 miles to bring the kids to school (no problems with starting or diriving) Its just enough to bring the car to its working temp. Then she stops for approx 10 minutes to let the kids out. She starts again. All ok. Then when driving about 100 yards, the engine cuts out completely and also quite sudden. When she starts it will start up but a bit hessitating. Then she parks the car (with engine running) waits till the engine is smooth and drives off. No problems after that. I pulled all the codes (nothing, not even pending) changed plugs and wires (OEM). Sprayed the wires. Still happens. 109k miles has new O2 sensors, new cranck-, cam sensors, PVC is new... I have the feeling it must be in the ignition somewhere. But there are no codes... Does this sound familiar to you? Any ideas? Jaap
Meet my 22B
JaapH replied to 666's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Then that must be like the same type of car I saw at my dealer 3 years ago (in The Netherlands). They were changing it from RHD to LHD and told me the whole job (including the purchase of the car) was more then $ 120k..... Now I know why. -
Thnaks for all the replies. No its not cold overhere (Seattle type of weather). Rattle comes from the inside of the car, and sounds like a loose bolt, but is not. Checked all. It only sounds when turning right on aa bumpy road. I had the suspension sound. Was more like a clunck (is that the way you spell it?). Took care off that. I am interested in the TSB they mention on endwrench(had the title of this post. If nobody has it I will download it. Thanks, Jaap
