rickdonkuless's Achievements
Newbie (1/11)
0
Hey Scott was wandering how much it would be for a adaptor plate and a redrilled flywheel
Thanks
You'll need everything that's shown here in this link: http://www.ultimatesubaru.org/forum/showthread.php?t=50400
Can u use legacy struts with xt6 knuckle also is it true that you can use legacy knuckles with xt6 lower controller arms
For the rear you need XT6 hubs, brake rotors, brake backing plates, calipers, but the rear axles should be the same as the stock 4wd ones. For the front you need xt6 struts, knuckles, hubs, brakes, lower control arms (the lower ball joint on the xt6 is a little different from the EA82 balljoint) and the xt6 front axles. At that point it should all bolt in.
-Bill
Hey man i wandering if you could tell me what i need off of a xt6 to make the swap. I know that need the hubs, but what else. The front i believe is just the knuckle and strut. Any help would be appreciated.
Hey bill was wandering if you knew what all you need to do a 5 lug swap
Hey josh heard that you got adapter plate from josh how much did that cost
I don't think that its a power steering bracket from a ea81 I think its from a ea82 I just don't know how that bracket is fitting on the ea81
