Jim Simmons
About Jim Simmons
  • Birthday 04/06/1943
  • Location
    Eureka Springs
  • Interests
    '63 Ranchero
  • Occupation
    Retired Mechanical Engineer
  • Vehicles
    2005 Legacy 2.5 GT
Jim Simmons's Achievements
Newbie
Newbie (1/11)
0
  1. OK, it has been awhile, but I drove the the car over a hundred miles yesterday and all is well...better than well, actually because while I had the car down I sent the injectors off to be tuned up. What I learned about changing belts on a quad cam Subaru, even though I had done this before: 1. Don't pay attention to the paint marks on the sprockets. 2. Before starting the job roll the engine over so that the two (2) scribe marks on each sprocket are pointed to each other, and the crank sprocket has its key way at the 6 o'clock position. There should be a mark on this sprocket at the top that aligns with a mark on the block at this time. 3. Now you can remove the idler rollers. The cams on the right side (passenger side in the USA) will just sit there as they are unloaded. The cams on the other side will more than likely spin suddenly, as they are loaded. 4. I recommend replacing all of the idler rollers if the engine has any where near 100,000 miles on it. Mine has 95,000 miles. The manual says replace them if you can hear them when you spin them. The kit I ordered came with the tensioner, even though the description said it didn't. 5. If your engine is a turbo with a 5 speed, the smallest roller included in after market roller kits will be wrong. Rockauto.com gave me a credit for $40, the correct roller from the dealer was $83 and I had to drive a hundred miles to get it. 6. After you get the belt in, pay attention to the scribe marks on the cam sprockets! The double marks must be pointed directly at each other. The right side marks are difficult to see without a mirror if the engine is in the car. It is easy to be off a tooth on the right side. 7. When everything looks well, pull the pin on the tensioner, and just for ducks, check the torque on all of the rollers you replaced. 8. I recommend cranking the engine two revolutions by hand, this makes every cam rotate once. By this time the belt should be running straight on all of the pulleys and sprockets. 9. Put the rest of the engine together (preferably with a manual) and the engine should fire up in the normal manner. The mistake I made that caused me to start this thread was that I was concentrating on the paint marks on the sprockets, not the scribe marks. I had installed the belt with the left side intake cam 180° off. I was fortunate that I didn't break anything. Thanks for holding my hand while I worked through my problem. I did take pictures, but I can't find my camera (go figure).
  2. Well...I pulled #2 injector and it popped out; plenty of fuel pressure. I put the injector back in and checked for injector sounds while cranking; they were there. I pulled a coil and checked for spark; had spark. So, y'all know what that leaves. It ain't gonna run with 10 lbs. compression. This suggests that I messed up the timing belt install. After the first start try I checked everything as I said in my first post. This is not the first timing belt I've installed on one of these 4-cammers, but I guess there is more to learn. I'll check back in a few days with an update. Thanks for the suggestions they are always appreciated as I tend to stand too close to the problem.
  3. Well I've seen stranger things happen. And so have I! I'm familiar with the drill but I've got it in my mind that I drove onto the lift and it was running great. It will wait until tomorrow. I have a community service job in town today.
  4. A shot of ether sounds like a good idea. I usually have some around for my neighbor's mowers, but I'm out, so I'll have to make a run to town tomorrow. As far as the belts go, I don't think I can do more than what I've said in the first post.
  5. I went out to the shop and checked the cam sensor. I did not remove the plug. Too hard to get to without unbolting the grounds. I'm sure about clicking the connectors because I never leave them until I hear it click. And the hammer comment...please.
  6. Cam sprockets were not removed, only the cover on the left side intake cam to assist in rotating with a 10mm Hex driver. I did unplug the cam sensor while messing with the injectors. I got a good solid snap when I connected it.
  7. I hate it when the new guy asks for help but has not searched for the answer, so I did search first. I have a 2005 Legacy 2.5 GT. It has 95K miles so I decided to change the timing belt and have the injectors tuned up by RC Engineering. After putting it all together, no start. On the off chance that I put the belt on wrong, I took the covers off and verified that with the crank key down and the reluctor tooth with the mark at the top, all four cams line up with the notches and the marks between cams are looking at each other. I've gone over the engine looking for loose connectors and unconnected ones. I've primed the injectors by turning the key on but not starting several times to pump out the air. The engine seems to not be getting fuel but the fuel pump runs. No codes, of course, the engine has not started. It cranks but no start. Bear in mind it ran fine before this work. What am I missing?
