89Ru
9
Everything posted by 89Ru
120 on all cylinders? Downright unusual to have bad rings on all cylinders and no oil consumption. Most if not all subaru's of this vintage will consume 'some' oil. Something is strange. Buyer beware. cylinder compression should be 180-210. Probably oil in the spark plug tube from bad plug seals, easy fix with dealer parts. Anemic performance is consistent with low compression. Blowby isn't a precision thing. Can have blowby and still good cylinder compression.
Well the subie is finally running and NOT stalling What fixed the stalling? Not sure but possibly something in the throttle body. I did a JDM engine swap, long block only. Kept the original intake. Still stalling in hot weather. Put the JDM intake on it with the original injectors and new oem seals, and changed/swapped some other bits that were incompatible (fuel rail, intake harness, coolant crossover pipe temp tensor, passenger side AVLS solenoid assembly, airbox hose to the block next to the pcv, plus longer brake booster vacuum hose to get to the right hand drive fitting on the intake). jeepers, this is why everyone keeps their intake. No stalling. Its been about 3 weeks of driving, city/highway in 88+ degree weather. Unless the mech at subaru changed them, the only two unswapped parts are the throttle body and the EGR. Everything else on the intake was swapped at some point. I'm cautiously optimistic. And maybe the original long block is probably fine as a spare if the rear main seal and head gasket(s) are redone.
What happened after you pulled the ABS fuse? Maybe the ABS pump relay is stuck closed, and/or the motor is dragging the system voltage down. What voltages are you getting when the pump is running? My 96 impreza had a continuously running ABS pump even with the ignition key off, and pulling the fuse fixed it, just no ABS system now.
Yep. I've started using subie OEM axles for my daughter's 07 OBW, worth the peace of mind. Hate spending $340+ for a single axle but my rebuilder is having reliability issues and I refuse to use aftermarket. Like has already been said, used OEM axles and rebooting kits from rock auto way cheaper, and messier. I've had good luck with removing the axle and rebooting. Never tried the split boots. I like to keep a couple of used OEM spares on hand for my daily driver.
JDM Engines?
89Ru replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Installed an 02 H6 four years ago, had issues with engine harness that were solved with using bits of the stock harness. No engine issues since then after 60k miles. Didn't touch the JDM head gaskets. Alt failed a few months ago but just normal wear. Swapped the stock intake over to the donor. There's a writeup on here somewhere for the whole job. I also have an 07 H4 JDM on a pallet waiting for me to put it in...I'll probably write that one up too. The only issues I've had with JDM engines is finding supply, and shipping damage, stock is low. Unwrap the engine completely and put some eyeballs on it before signing the delivery paperwork or that shiny creampuff is yours, damage and all. -
alternator swap
89Ru replied to 89Ru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Up and running with the DB alt. Windings of the reman alt look blackened. So wondering if a winding shorted out since it was charging for a few minutes. -
alternator swap
Yes, DB is in Kingsport. I supported my local parts garden and scored an H6 alt. While the H6 and 2.5L alts both have a 3 pin connector, it appears that only the H6 uses all 3 wires in the harness. I noted that a 2006 Forester 2.5L 3-pin green alt connector only has two with populated pins on the harness pigtail. That being said, I wonder if the H6 alt could serve as a spare for a 2.5L model? Parts store says they will take the reman alt back. -
alternator swap
Ok. I had heard about H6 alt needing ECU input so thx for confirming. This alt is already aftermarket so must have gotten lucky in the past. Local yards are pretty picked over but might try my luck again. This was a sunday night save the day job or so I thought. https://www.maniacelectricmotors.com seems to sell rebuild kits. Haven't been able to get enough heat to disassemble the electrics. Local alt rebuilder hasn't updated FB page in 5 years and phone is disconnected If anyone knows a rebuilder in Nashville lmk. https://www.dbelectrical.com ships overnight. looks like my best option for the H6. -
2002 Outback H6 Sedan suspected alt failure. Can I swap out a known working OEM alt from a 2007 Outback 2.5L after swapping the pulleys? Looks like output current is about the same 100 on the H6 and 110 amps on the 2.5L. Connectors look compatible. The background. Batt and brake lights lit on dash on a road trip, driving fine otherwise, headlights shut off (at night of course) and car dies about 30 min later. Presumed alt failure, is a reman unit, about 5 years old. Battery is 2 years old. Charged battery to 12.8v using external charger. Installed a reman unit from parts store. Car starts and alt charging at 14.x volts, dash lights back to normal. At some point during 10 minute idle, alt stops charging. Batt voltage drops to 12.x volts and headlights (normally on while car running) turn off. Batt and brake lights on dash as before. Battery/alt/starter harness replaced about 5 years ago. Could there be some other failure that killed the new alt too? Going to bring failed alt to parts store and get it tested, get replacement if possible but if that falls through I have a spare alt from the 2.5L.
Pulled the driver side head off. All the bolts creaked and some thread shavings on at least one bolt. Visible fluid trail on the cylinder walls of #2 and #4 at 6:00 (bottom of cylinder). Looks like oil and coolant mix. Same section of the head (bottom) is oil stained. Heads look different from when it was an obvious coolant leak (prior job). Exhaust valves were clean before, now they are carbonized/oily. Don't think its bad rings. Compression and leak down test was ok. Could be from the oil galleries? (low pressure) or from the oil high pressure side on top? (the high pressure section of the gasket looks suspect to me). I used subaru turbo multi level steel (mls) gaskets. Wondering about flatness of the block. Heads were decked previously. Going to clean the block and head with 3m 120 grit white abrasive disc. Waiting for a decent mech straight edge. I don't trust my old straight edge anymore for assessing the flatness of these surfaces, but there is light showing through.
I think a lot of the oil down under is due in part to a bad oil pan seal (done by po) and the drivers side head cam retainer plate (I call this a cam cover??) done by me. And yes I sealed it but looks like I need to rethink how I did it. I think the cam retainer-cover leak is getting oil all over the drivers side exhaust gasket. Valve covers are leaking a bit.
Pulled the engine, tb covers, intake, drivers side cam and inner tb covers. Crank seal is wet but not leaving a huge trail. Cam seals are both dry. Plugs #2 and #4 are wet with oil. Crank pulley has all its teeth, maybe some of them are need a good brushing tho. Cam sensor is shiny goodness. Still digging. Have to pull the drivers side head. Not sure how far this is going.
Just took possession of the car, after a solid 6 months at the subaru dealer. I'm embarrassed what I paid for the diagnostic fee. Incidentally the car behaved itself on a 20 minute drive city/hwy. Idled in the driveway like nothing was wrong. No stalling. No misfires. No cel. Blowby was present on the oil cap several years ago, so I presume it is no better. I'm sure it is burning oil. Crawled underneath. Lots of oil, mostly from the timing belt cover. This isn't new, and I thought it was from either bad crank/cam seals (all replaced when I did the heads but probably not oem, my bad) or the oil pump needs a reseal. Head gaskets are dry both sides, top and bottom. Coolant overflow is a bit lower than typical (I like to keep it filled 3/4) so its possibly consuming coolant. Rad is full. Also, maybe I'm reading into this and searching but there is a faint thump/knock sitting at idle I can hear in the cabin. Can't hear it in the engine bay. I don't recall hearing that before. Mechanic said he did a leak down test and all cylinders were "low" but he said was normal for age of car. The car has had oil consumption ever since I bought it. I'm kinda used to that with subarus, but this isn't "normal." Recall this car had a clogged cat a while back, after I did the heads. That was fun to figure out. Not sure if its related to internal oil leaks. Someone help me get this engine on the catapult.
Using a LOT of oil. Maybe a quart every 2-300 miles. Oil turns dark quickly after a change. Not using coolant or the typical gasket problems you would think of like gurgles in the cabin on startup and acceleration from exhaust bubbles being piped through, or coolant overflow tank rising and radiator level dropping, with no transfers into the rad on cooldown. None of that. Trust me I had all of that in the initial HG failure. And burping doesn't fix it. That gurgle gives me the shivers lol. I don't recall problems with oil on the first HG failure. Not overheating now. Some oil smoke on startup from oil in the chamber but that clears. Regarding the torque specs, just relaying what the mechanic told me. I sent him my 2007 and 2008 fsm head bolt specs. He claimed he had never seen the 2007 specs I sent him and thought I was using Haynes. During work on the exhaust I noted wet oil on the exhaust port on #2 after dropping the front cat. So there is likely a lot of oil in the chamber mucking things up. When I did the head gaskets I didn't tear down the heads to the point of replacing the valve seals or lapping the valve seats.
Car was new to me when I did the heads in 2018. Previous owner didn't even own it long enough to get the title in his name. I think he figured out the car had issues. I quizzed him at length on potential head gasket problems, even did an coolant exhaust gas test (negative of course) before buying it. You know how that ended. I prepped the block surfaces with scotch brite and a blade where needed. put a flat edge on the block. There is a long post on the first head install. Basically the first machine shop messed up the heads (sanded them) so I had a coolant leak and it wouldn't hold pressure after I bolted them down and filled the block with coolant (prior to engine install, was just basically being super cautious). So I took the heads to another shop. Strangely enough the engine has glued on pop-up temperature sensors on the firewall side of the heads. Like the kind that indicate an engine has overheated. Mine are not popped up. Maybe the engine was replaced during the previous previous owner's ownership and somebody thought to add the sensors for liability/warranty coverage?
Premature head gasket failure after 35k miles. The troubleshooting: OEM MAP didn't solve it. Saga continues. Car has been at the Subie dealer for over 5 months chasing the hard stall issue. Subie mechanic tells me he has swapped over everything electrical/sensor related in the engine bay and no happiness. The bad: So now he thinks it is a head gasket. Is losing a LOT of oil spilling onto the exhaust and smoking from the engine bay. Exhaust gases in coolant. He thinks the stalling is caused by severe loss of compression from a huge leak. Once upon a time the stalling only occurred during the summer and only after warm-up. Now it stalls in the winter too. Wants $4K to fix it. I did the head gaskets about 35k miles ago, pulled the engine, had the heads machined by a pro, used OEM turbo gaskets, torqued to spec. Re-used head bolts, meticulous on cleaning head surfaces and head bolt holes and threads. The sad: Subie mechanic looked up the head bolt torque specs I used and says I used the wrong specs. I got the procedure from the 2007 factory shop manual. I noted when I did my 2008 EJ253 head gaskets (same engine as the 2007) the torque procedure and specs were DIFFERENT one year to the next. Anyone else notice this? My 2008 is running awesome. No gasket leaks. Everything else was the same (machining, turbo gaskets, yada yada). Mech thinks the bottom end is fine. Compression is good, just bad head(s). So what to do? Have the dealer fix it for a pile of cash? Redo the heads myself and use the 2008 torque specs? Maybe throw a new set of head bolts in there. Spend $2500 for a JDM EJ253 and do an engine swap? Any help is awesome.
Update. Verified that the fuel injector covers are swappable left to right on the intake, however due to interference with the oil filler tube, the intake will NOT install with the injector covers reversed as previously thought. So the defect on the drivers side cover was preexistent. Used a cut off wheel to remove enough material (a sliver) for the intake to install flat to the block. Bolted it up. No codes. Will edit previous posts.
Removing CV axle
89Ru replied to awdonry's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
So you were able to get the axle pressed out of the hub. Good job to all. Getting all that irregular knuckle metal/mass balanced in a press can be a bear! At least you have access to a press, as your wheel bearing is press in/out. Getting a ball joint out without a special tool is no fun. Ball joint tools are not expensive. A bull pin is cheap and effective but has the risk of tearing the boot. -
Removing CV axle
Always nice to find OEM axles. I have whacked things for hours in the past. Sometimes a better tool is the answer, such as a hub puller like OTC 6574, a beast. Probably didn't bother the transmission, it's mostly solid metal anyway and some of that force goes into the control arm. -
Removing CV axle
Yes, remove the axle from the transmission so you aren't hammering against it. With the strut free you'll have some play to swing the knuckle away from the transmission and out pops the other end. Make sure you take out the axle pin on the transmission side first.
