89Ru
9
Everything posted by 89Ru
lost power, how to replace crank angle sensor?
89Ru replied to 89Ru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Whoops, I got off on the wrong track. Distributor isn't the main problem, its the driver side timing belt! Must have broken or slipped (hitachi rotor isn't turning, why didn't I check this first?) It only had 55K on it... Never done these before. I have found some great posts on how to do it with pictures...looks like a lot of stuff may have to come out first (alternator, radiator, A/C) Car has 257K, should I do this? How many hours for a novice? -
Correct, died while driving. Tach went to zero on the crest of the bridge. Thanks for the confirm on the wiring. I'd like to get a little deeper and dig into the part to replace the amplifier...I hate to throw things away...but that would be a research project (is it already?) I found a site that offers reman. distributors for 22100AA440, D4P86-03 www.ccrengines.com/roobuilders/ Oops forgot, this whole car is a research project -
Glen, Reading dneufelds post has me wondering about my hookup He states "red power / black reference / white position / green ground" My hookup: red power / green reference / white position / black ground I base this on my FSM which says: GB power GY ref sign BW pos sign B ground I suppose '87 and '89 could have different wire colors...just wondering. The CAS was drawing 31 mA at 12V on red --> black Michael -
Cougar, The reference is the larger spaces in the wheel, right. My voltmeter was wandering around in 0-200 mV on the ref signal no matter if I was turning the shaft or not, where the pos signal seemed to go up in voltage only when the shaft was turning... Regarding your 2nd question, according to the FSM procedure, I checked the body side of the CAS connector. Using the (-) battery terminal as a reference, I found good 12V, and 5V on the reference and position pins (pullups on logic inputs?), plus a good ground so I think the connections to the ECU are good. With the distributor sitting on a bench by itself, powered with 12V, while turning the shaft, I used an oscilloscope to look at the reference and position pins from the CAS. Voltage levels look rather low (4mV peak), these signals are referenced to the black wire (GND). I would think these should be logic (5V) signals...the pulses are there though...the position signal has a low frequency pulse upon which the 1 degree pulses appear, riding on top. The reference signal has a dip that I think marks one of the four wider slots on the wheel. I tried to add a pic of the scope screen, hope it works... hitachi_89_crank_angle_optical.bmp -
Thanks, my transistor whatsiz (ignition pulse amplifier) is original so it could be bad...so is my coil (shhhhh!) Cougar I think you are right about the magnetic pickup being the wrong part...after checking for voltages on the crank angle sensor connector (they are ok) I took out the distributor and with a meter, checked the reference and position signals. As I turn the shaft, the position signal responds but the reference signal wanders around in voltage...which seems to match the code 11 (bad reference). I might check with an oscilloscope to verify this... Had to tow it on a flatbed...so its a lawn ornament until I can find a new distributor...no parts shops seem to have the sensor electronics as a replacement part... Vehicle registration stickers just came in the mail, good for two years...anyone think it will run again before they expire? -
Here's a pic of p/n JA115, since I haven't torn into it I can't verify this is what I need... http://partimages.genpt.com/partimages/227669.jpg Look right? -
Thanks Cougar for the tips. I'll do it before anything drastic. Am having trouble finding the exact part match. BWD: CBE507 NAPA: TP120 GP: 10-5001 NIE: WA910 SMP: LX-515 WELLS: JA115 Crank angle sensor, 89 Hitachi distributor? Names, prices vary too, from $63 to $180. -
Last night got a CEL over Severn River bridge. Lost power, coasted down under a streetlight. Same bridge where my hood flew up although this time eastbound. ECU says code 11, crank angle (no reference pulse) About a week ago I cleared codes so this is probably fresh. Do I have to pull the distributor to change this out or can I do this roadside? I have the FSM, page 6-1-27 shows a pic. I have until tonight before I'll need a tow...the 24 hour thing. 89 GL 3-door SPFI, optical distributor
Whoa, connected the white ones and the ECU had quite a story to tell, like it had bottled up years of memories without anyone to talk to...to me this sounds like "read memory" mode According to the FSM: Connecting green (test mode) connectors = D-check mode (fuel pump runs intermittently) Connecting white connectors = Read memory Connecting both green and white = clear memory (with engine on) Thanks for setting me straight on this.
Huh? Looked in the FSM and no mention of code 05...in both U-check mode (green connectors under hood unplugged) and D-check mode (green connectors plugged together) with ignition on (engine not running) I read five fast blinks on the ECU led, separated by a ~2 sec. gap. I read this as a '5', is this right? No slow blinks that would indicate a '10'... I got a CEL a week ago while driving at slow speed, but it went out quick...thats what started me on this...hasn't lit since. I wonder if this is a specification code, but I don't recall it ever indicating this code before... 89 GL 3-door dual range
cold weather mechanics club....
89Ru replied to torxxx's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Never thought of that. Such a good idea it deserves a bump. An old electric bathroom heater/blower with a windscreen works nice to cure underbody tar overnight at 30-ish. Never mind that its 70 degrees warmer here than in Alaska. Makes my fingers stiffen up, my mouth gets so cold that words can't get out. -
'95 legacy has OBD II (verify sticker under hood). Subaru adopted the standard a year before they had to. You'll need a scan tool to read the codes. Search this board for scan tools, a variety of features (and prices!) are available. Codes are stored for 40 warmup cycles if CEL goes off so you don't need to be at the dealer when the problem occurs.
Be careful with your cooling system. Bubbles are bad. Here's an excellent post from setright Coolant Replacement, minus the big air pockets :-) Hiya everyone, maybe this write-up should be moved to the Ultimate Subaru Repair Manual, but I thought I'd hit a bigger audience here. Having replaced coolant on my boxers many times, I have been searching for the right way to get all the old fluid out and getting as much new fluid in, without having to burp the system for a week after I'm done. I think I have finally cracked it! Draining Drain the radiator as far as possible with the little "faucett", and then detach the lower hose from the radiator. (If you are like me, replace any coolant hoses that you remove, and use stainless steel clamps on the new ones) Even more fluid will drain from the radiator, and some will drain from the engine block. Detach the upper hose from the radiator, and run clean water through the rad until it comes out of the bottom clear in color. Now, I do not contest that the best way to flush the engine block is by unscrewing the two drain plugs, but these are often seized and could turn into a source of trouble if you strip the threads or if they won't seal tight when you screw them back in. SO, I jack up the rear of the car until the engine block is tilting slight forward, ie. wheels about 6 inches off the ground, unscrew the thermostat housing, and let the old fluid run out through the thermostat opening. (Needless to say, I replace the thermostat gasket) Run clean water in through the upper hose until clear water comes out of the thermostat opening. Leave the car in this position until it stops dripping water. Remove the expansion tank and flush it, there will be plenty of "snot" in the bottom of it! Rinse the hose too. Install the tank again and fill to the FULL mark. Filling Close up the bottom end of the cooling system, ie. thermostat and lower hose. If possible, perform the next phase on a slight incline, car pointing upward. Get a funnel with about 10 inches of half-inch diameter hose on the end of it and slide this down the upper hose in toward the engine block. I do this because bending the upper rad hose causes it to collapse and that makes pouring coolant into it impossible. Pour your preferred coolant directly into the engine block. Pouring slowly, and pausing along the way will help keep air from being trapped inside the block. It should swallow at about two litres before it starts to rise and threaten to come out of the hose. At that point, attach the upper hose to the rad and continue to fill slowly through the rad cap hole. Once it seems full, start the engine, let it run for twenty seconds and shut it off again. This will dislodge the few air pockets that are unavoidable and the fluid level in the radiator should drop a little after the burp, top it off. Start the engine again, and let it run until the fluid rises and threatens to come out of the rad cap hole - and bleeder hole if you have one - and install the rad cap. Take the car for a shortish run, just a few miles to get it fully warmed up, and park it on level ground. Check hoses for leaks of course, and let it cool. This will take a number of hours, overnight is good. In the morning, note the level in the expansion tank, it will probably be a little lower than FULL. Fill to the FULL mark, and you're all set. Obviously, you should check the level in the expansion tank for a few days afterward, but there shouldn't be any problems. Resist the temptation to open the rad cap, this will only interfere.
ASAP Motors (Texas) www.asapmotors.com I bought an EA82, put 50K on it over last two years, no problems. Shipping was around $75 to Maryland.
Solenoid is $85 at subaruparts.com in Tacoma WA. Don't even need a p/n, the nice folks there look it up for you, just fill in the online form.
P74028 fits in the stock location with some encouragement. By the way, both Morganm and Arch I think have installed 2P74028 inboard, which is better spacewise, but noisier. I installed the Napa pump P74028 ($100) using two stainless marine grade hose clamps plus the stock rubber shock mount (hammered to fit). The Napa pump is 2" diameter (bigger than stock and heavier). I chose to install it backwards because the outlet fitting is long and intruded into the body. Regarding the P74028 (may not apply to 2P74028)...in my opinion the shock mount is inadequate for this heavier pump and the backwards install may require tight bends in the lines. If I had to do this again I would search for a right angle mod for the outlet like on the stock pump to possibly avoid the backwards install. As mentioned, you'll also need some kind of fitting to adapt. I used a 1/2" to 3/8" hosebarb NPT fitting pair, 57001-0806 and 57002-0606 at cornerhardware.com to go from the fuel tank hose to the 5/16" inlet on the new pump. Use fuel-rated pipe dope on the brass NPT threads, plus marine clamps. I used more flexible 50psi 5/16" line for the inlet since the Napa EFI 5/16" line was so tight it wouldn't go past the third 3/8" barb.
When you say "EGR light" I'm assuming a lot: 1. CEL on 2. Trouble code 34 --> Failed EGR solenoid If you want to double check, to verify a bad EGR solenoid check the coil resistance by disconnecting the connector and ohming the contacts, a good coil reads about 35 ohms. Besides the tape trick, replacing the solenoid should clear the CEL by itself. Good post here on this subj, how to find EGR, etc.: http://www.ultimatesubaru.org/forum/showthread.php?t=12057&highlight=solenoid+code Good luck
Thank You ALL!!!!!!! Problem solved
89Ru replied to bella's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Bella, Congratulations! Your English is far better than my Romanian. 89Ru -
Bella, I accept Paypal. Or...contact my friend in Suceava. You pay him and I'll send the parts. My friend is a Christian. He speaks Romanian. Northguy/Seahag- if you are already sending parts to Bella I'll back off. Mike
Where to find METAL Fuel line t-fitting?
89Ru replied to Flowmastered87GL's topic in Old Gen.: 80's GL/DL/XT/Loyales...
For my fuel lines I found cheap brass fittings at cornerhardware.com (shipping costs far exceed the part cost but all the auto/hardware stores I looked at had a subset of what I wanted) -
Should I part it out or spend some $ ?
89Ru replied to Chongo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Chongo, Why does it need a new alternator? If you are like me, you want it replaced just because its old. I did mine at 200K for about $88 before a 1500 mile trip, but it wasn't showing any signs of needing it. I understand the strange affection that may convince you to spend a few bucks more than the car is 'worth' (what a willing buyer will pay to a willing seller), but doesn't take into account the value of the invested time and knowledge of the repair history of the machine. I have yet to see a Subaru die so I have no experience about when to make that decision. My first Sub is like yours but 3 years younger. It has been taking more encouragement to keep running lately, so rather than dumping it I bought another Subaru. What I would do is: Get the seals done so its not an oil spreader. Get the exhaust holes patched so it doesn't stink. Attach a CO detector to your visor. Run it until it dies a definitive death. What's up with Virginia inspection? Did you recently buy the car or is this an annual thing? Maryland has frequent exhaust emissions testing (and fortunately doesn't care about other emissions prone to Sub's). My wife has a brother that lives in Manassas that we visit here and there (90 min for me). If you part out your creampuff let me know. 89Ru
