Slamngears5
About Slamngears5
  • Birthday 03/12/1986
  • Location
    kokomo
  • Vehicles
    1992 legacy wagon AWD
Slamngears5's Achievements
Member
Member (2/11)
0
  1. Ok i understand... Ive just been around 2002 and up Imprezas WRX and STi's 2005 and up Legacys i wasnt sure how this mod worked on my 92 legacy wagon what is the max speed you can maintain with this mod??
  2. Im going to sound like a complete idiot but what are the advantages and disadvantages of doing this and does it lock all four wheels in drive im sorry im clueless on this im used to newer subarus and this is all so new to me
  3. Yeah sounds good we will definately have to set something up
  4. Reset the ECU and codes 31,35,and 24 came back im assuming code 35 isnt the problem so now i need to figure out what to do for the other two
  5. We have GOT to get together sometime. I'm 40 minutes south of Indy off I-65. Would LOVE to sit and chat or wrench with you sometime. I could use a little coaching.
  6. Thank you i pulled the codes (a 24,31,32,35) not sure how much its going to help me ive already replaced a couple of these parts im going to reset my ecu and see what comes back and go from there
  7. yeah ive done the ether trick i even replaced my IAC and new gasket i cant find a leak anywhere that was my first thought also
  8. it started all at once yes there is a check light on but this is my first OBD1 car and i am clueless on how to retrieve codes i just got the car a month ago and it set for a few months before i got it so i put some fuel injector cleaner in it along with an oil change plugs and wires a new air filter at first it had a rough idle then one day all this started happening so im clueless
  9. my 1992 legacy wagon AWD Automatic is idling high around 1250 rpm when its in park or neutral with no load it revs to 1250rpm then drops to 1100 rpm then back up to 1250 and drops back down and so on when i put it in gear the rpms drop to about 800 for the most part it drives fine except for when i keep it constant at about 2000-2300 rpm it does the same thing as above so i have to keep the rpms out of that range which is difficult in city driving does anyone have any ideas im at a loss right now
  10. Coming from a former SVX owner you dont want a stock or rebuilt SVX 4eat i had 2 explode on me and ive heard of several others going out i would just take the extra time now to put a better trans in my theory is you can make anything work with enough time and money lol
  11. Type of Wrenching: Good Ol Shady Tree What: Subarus new and old, and any other car you throw in front of me How long doing it: 8 years or so Other skills: Worked at the Subaru factory Doing Paintless Dent repair, certified welder, pretty much a "Jack of all trade Master of none"
  12. thank you everyone this site has been so much help already!!
  13. Hows it going i stumbled on this forum today doing research on my 92 legacy wagon AWD this is not my first subaru ive had a 94 SVX Ls and a 2008 legacy 2.5i but my 92 legacy is my favorite by far.... Im located in central indiana and a member Indiana Impreza Club
