Everything posted by [HTi]Johnson
Last of the EA Full Time boxes viscous ?
yEAH YEAH rub in the fact that you have EJ dual range boxes.
Allied Armament's old buy thread, you all got your stuff yet?
Was this resolved?
Identifying EA82 Vac Hose
I can tell you that that doesn't have much to do with the EGR. The EGR is a little saucer shaped object that is attached under the carb on the back side of the manifold, with a little vac line going to it and a metal tube with a thread fitting.
86 to 89 Ea82T info needed
I have a couple of mpfi intakes...but I don't know how you would bolt a carb up to it without some machince work. Maybe we could work something out? It actually wouldn't be hard to make a carb adapter that sits where the Throttle body was. If you went that way, you wouldn't have to worry about tearing the engine apart as long as it passed leak down. PM me we can work something out. How would that run anyways? A MPFI block with a carb?
Seafoam+spark=YOU GUESSED IT!
I can't believe no one has done this!! :Flame:
1989 RX with 4eat
I have a left foot!!! I even use it to clutch a brake pedal sometimes when I get spaceheaded!!!:lol:
to the pipe fittings gurus does this exist
They are pretty cheap if you can use plastic....
That probably looked badass...especially if it was at night. yeah, any damage?
blown 3 axles in less then a week
Like this? :cool: Just a prototype...gunna test it out.
1989 RX with 4eat
Mine's white!!! Hahah. I want to convert it to 5speed, no doubt. But I might just wait and do a full ej swap.
1989 RX with 4eat
Is that normal to have a full time awd automatic in a 1989 RX? People have told me that it wasn't.
87 rx axle part number please
Auto or 5 speed?
You can manage to turbo that. It's not much different than people using a spfi block for a turbo.
1980 to 1984
The tranny has a bell housing. The engine has the other half. If you look at it, you'll see where it splits in the middle. The engine side is the side that needs to be removed.
SPFI almost done!
Thems some technical drawings:D
If you're proficient enough to setup and use a stand alone ECU, I have a megasquirt unit I can sell ya. This will alleviate the need for a MAF and open the engine up to more mods. Is the intake already on? With all the engine harness and wiring? If so, getting a stock ECU for what ever year range and wiring harness wouldn't be hard.
baja exterior plastic
Do you think you need a whole bumper or did just the plastic get fubar'd? Check with a local auto body shop, they might be able to point you to an aftermarket parts supplier.
1980 to 1984
It sure beats the crap out of a 3at!!! You could take the bellhousing off the ea71 and bolt it to the ea81 engine. It won't be hard because you'll have the tranny out anyways. And it'll make changing the rear main seal WAY easy. Changing the rear main is a must because you already have it apart and it would 1 min to change. If you wait to change it, you have to remove the tranny and flywheel to get to it. You'll need the pedal assembly from the donor car too. But you need to find out if it will work since it's a ea71. Shifter components too and a way to plug some of the hole up where your shifter will be...like a piece of metal. Because the automatic shifter requires a bigger hole. I used a piece of sheet metal, caulked it and pop riveted it in place.
rx tranny question
To add my 2 cents... You're car is in AWD with the lever down. All wheel's are powered. When you lift the lever up, it puts it into a lower range of AWD, lower gearing for...say climbing steep inclines. When you flip the diff lock, it splits the power %50 to the front wheels and %50 to the rear. Only use this on slippery surfaces like gravel, mud, snow. I'd be careful with the gravel part. If you use it on pavement, you can break some components of your drivetrain.
85 Brat prior to lift installing advice...
Well, depends on if you're buying the kit or building it? If you're just installing it you need: Floor Jack Jackstands Metric Socket set with socket Wrench Metric Box wrenches PB Blaster (just in case) Impact Wrench (can be done without, but makes it easier) Safety glasses (so crap doesn't fall in your eyes) Philips screw driver.... that's all I can think of right now. It's pretty basic stuff.
Should I go for this? UPDATE: I went for it!!!
I hope not, I think Honda produces more cars than Subaru does. If there are the same amount of crapass Hondas as crapass Subarus, that means a higher ratio of Subarus are crapass. But, I know what you meant, (ratio wise) I figured I'd just add a pointless comment to a post that has gone way off point of the OP.
I would almost put money on them being the same as legacy's. It Subaru's economic style to make most parts interchangable, but you never know nowadays. EDIT: Yeah, I'd say they mount the same, but have different molding patterns.
You're gunna end up with the somewhere else! HAH, just kidding. Have you ever worked on a Honda? Let me tell you that after working on Subarus for years (a whole 5 of them ), I had to do some work on my GFs Honda, I wanted to shoot myself. The oil filter is on the BACK of the engine, closest to the firewall, above the exhaust. WTF. Then the thermostat can't be in the front of the engine, it's gotta be in the back too, almost completely underneath the intake. As for the original post: good find. are you going to use it as an EJ swap sooner or later?
When I install the kits, I extend the rear brake lines, because my lifts lower (lower: as in raise the body off of it) every rear end component except the mustache bar. I use a double female connector with a 4" extension brake line. I put the double female on the line coming out of the body, that goes into the soft line and then attach the extension, then put the extension in the soft line and attach the extension to the double female. As for the exhaust, you should be able to get away with having it mounted in the stock locations, as most of them are attached to the pieces that get lowered. You'll need gas lines, to be safe. Custom-ish radiator hoses (just have to find what fits), pitch stopper might need to be extended, steering shaft extended, and shifter(s) extended.
anyone seen this before?
Forgot that part :-\
