Everything posted by [HTi]Johnson
2 new questions
[HTi]Johnson replied to hardtail_pride's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I assumed he used a light, probably did. -
First lifted wagon w/ pics
[HTi]Johnson replied to Greenley's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Very nice:headbang:. I wish that was "Just behind my house" that scenery is awesome! -
2 new questions
You need to put the car on 0' TDC For the #1 cylinder and then put the distributor in, pointed at the #1 plug wire. It's probably a tooth off. Then re-time per your vehicle. -
The water pump depends on if you have a mechanical fan attached to it or not, I believe. As for a parts source...check this link out. I recommend the "SubaruPartsForYou" site. Since you have the T-Belts off already, replace the oil pump seals, front crank seal, cam seals (There is a regular seal and a o-ring that sits behing the plate that holds the regular seal). So, once you replace the cam seals, front seal, and oil pump seals, it shouldn't leak anymore...or much...it's a Subaru, they always leak slightly. Here's a link to a timing belt procedure.
Another PNW soob-noob!!!
[HTi]Johnson replied to Schatzi's topic in Meet n' Greet. Your USMB Welcome Center
I think he got bit by the bug. -
This is a blow to the trust that this community has with one another.
Axles will not divorce the diff
[HTi]Johnson replied to Uberoo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I've done that. But he doesn't have a welder and he's probably trying to make it easier on the guy that does have a welder. -
Dude that sucks...I hope it isn't for good, I always hate to see stuff like this happen. :-\
Nice!
How familar are you with the EA engine? Did you do the timing belts right?
Grounds? Do youhave adequate grounds?
Rear Axle Questions...
[HTi]Johnson replied to 88RxTuner's topic in Old Gen.: 80's GL/DL/XT/Loyales...
All ea82 rear axles are the same. -
EA82 problem need some advice help
[HTi]Johnson replied to cole098's topic in Old Gen.: 80's GL/DL/XT/Loyales...
AMEN! I love those things. I just wished they had them in the offset wrenches like these . Harbor Freight has those, but only standard. They'd be good for that lower b!+ch bolt on the driver side tranny. -
I've heard that sometimes all they want is to be fed and beer:drunk:. But now-a-days, maybe some gas money. -
Question about EA82 motor
[HTi]Johnson replied to Tcat55371's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I'd assume these, if he's using them again...but you never know. -
That's what they are, they are a metal ring cover with rubber to be general. They cost 2.63each at http://www.rockauto.com and you need 2. You have to take the cam cases off each side of the engine. Maybe you can talk a board member to help you out, if they live close, it's not too hard of a job...when the engine is out of the car. -
Check your oil , if that is good, Change your oil and use a subaru oil filter. Use a good name brand oil, I use castrol high mileage 20X50. Then run it for a while...if the ticking doesn't go away, you may have to reseal or replace your oil pump. But, the ticking isn't harmfull, my RX has it most the time. Just embarassing. Does it sound like the ticking is from each side of the engine or a certain side/piston? I'd drive it like it is. Also, welcome to the world of EA82. That is referred to as the "Tick of Death (TOD)" But it doesn't mean your motor is gunna go, just a funny name. -
Slideshow of my old Brumby
[HTi]Johnson replied to Phizinza's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I've only had these things break more than any Subaru I've had. You'll see that things break on anything, no matter what the platform. Cool video though:popcorn:. I like the bumper. -
So it doesn't move in any gear?
taking a little trip
[HTi]Johnson replied to subaruguru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Uhhh.... J/k I want a meet in greet! I'm upi in Orygun though. -
Need Honest Opinion....Reality Check
[HTi]Johnson replied to Bucky92's topic in Old Gen.: 80's GL/DL/XT/Loyales...
So merciful!! That mad me laugh pretty hard. -
Congrats on the two years. My G/F and I just had our 7, yeah we got together in high school at 15, ok done with my life story. What about spare hoses? Spare axle? I think you'll be just fine though. It's always good to carry extra stuff, cause you probably won't need it, but if you didn't have it, you would need it. And a good jack with a jack stand? Duct tape!!:headbang:I've seen that hold a 1" gash in a coolant hose. -
I'm still waiting for mine...kinda sucks being 2 months into the year.
