Everything posted by [HTi]Johnson
what grade are the head bolts, and what type of steel? just your common steel, heat treated? Thanks, I tried searching, maybe I just missed it.
Just a Question
[HTi]Johnson replied to ()__1337_CRAYOLA__()>'s topic in Old Gen.: 80's GL/DL/XT/Loyales...
Look what you started LEET. GD, I know what you mean about that whole walmart gauge shiz, what a PITA. I am looking for a digital one, they seem to be pricey though. Any ideas? -
okay, what's going on here? (94 loyale)
[HTi]Johnson replied to Snowman's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Timing? Timing belts? Maybe you broke the passenger's side? -
WJM is at it again...N/A EA82
[HTi]Johnson replied to WJM's topic in Old Gen.: 80's GL/DL/XT/Loyales...
UGH, it not my money, I agree. -
Just a Question
How about he gets a more dependable/accurate oil pressure gauge and then reassess the oil pump. -
TOD thread #245234521355
[HTi]Johnson replied to NewDriverOlderRide's topic in Old Gen.: 80's GL/DL/XT/Loyales...
3 hours or so....remove the radiator. -
GL-10 4EAT torque converter did what?
[HTi]Johnson replied to electryc_monk's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You just need to take the convertor off and pull that stub out and twist it a little and push it in, semi-hard (don't use any hitting tools ) It'll go in. -
Yes, as long as you connect the black connectors.
Yeah, either replace or reseal the oil pump. When you take it out...look at it for scarring on the pieces...if it looks good, a reseal would suffice, you can get a kit at Napa. While your in there you can repack the Tensioners as GD recommended and replace the timing belts, or buy this Good Luck. -
Can't Get It Started
[HTi]Johnson replied to sunflowersubaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
check timing. How about your timing belts? There are two, and the passenger side could break and the engine would run, just rough. Does it "rock" back and forth pretty hard? -
only $180 for them all and like $45 shipped! NICE!
85 subaru hovercraft engine
[HTi]Johnson replied to Bob Zang's topic in Old Gen.: 80's GL/DL/XT/Loyales...
My first thought is a ground wire. -
EA81 gaskets etc in New Zealand?
[HTi]Johnson replied to cubastreet's topic in Old Gen.: 80's GL/DL/XT/Loyales...
try www.ebay.com and www.thepartsbin.com -
Megasquirt Kit Assembled.
[HTi]Johnson replied to [HTi]Johnson's topic in Old Gen.: 80's GL/DL/XT/Loyales...
HAH HAH howcome all the interest now? . I'm tooling around with making my own connections for the harness. It will plug in to the harness where the (secret). -
3 XT6 running problems
[HTi]Johnson replied to xfinrodx's topic in Old Gen.: 80's GL/DL/XT/Loyales...
1: Do a compression test on all cylinders. Does it get hot on the gauge? Check the thermostat. 2: Kinda sounds like a timing issue. Follow step 3. 3: Have you checked the timing with a timing light? There are two connectors that need to be connected prior to timing it on the #1 cylinder. Have you checked all plugs and wires? Make sure the cap and rotor look good. Take the timing covers off and put the driver's side cam straight up and the passenger's straight down. Like this: (driver's) (Passenger's). Then you should see these three marks, with the arrow on the center one. If one pulley isn't in the right spot (Like the picture shows), but the other is, your valve timing is off and follow this to fix it: Good Luck, I hope my rambling helped, Justin. -
Transmission conversion
[HTi]Johnson replied to boozen's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I second Northwet, that thing they call a "search" function is crap. I've been on the Board for almost 2 years, and still aven't figured out the search enought to use it efficiently. So the answer is yes. You can convert. -
Factory service manual for download?
[HTi]Johnson replied to leon's topic in Old Gen.: 80's GL/DL/XT/Loyales...
http://www.ch601.org/engines/files/SubaruEA82-ServiceManualPart1.pdf http://www.ch601.org/engines/files/SubaruEA82-ServiceManualPart2.pdf -
I've used Accel Super stock (8140 or something) coils for 4 years now, with no problems. Some people will say that it will fry some stuff. But with 4 years of nothing but good, I'd say it's safe and the "frying" was probably an error on someone's part.
i have too much free time.
[HTi]Johnson replied to subyrally's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Freakin' sweet. I know showing off the FMIC looks awesome, but I think you should put some shielding in front of it! Like some expanded aluminum, even if it had 1/2" holes through it, it would protect it from the debris that would do damage. Justin Johnson P.S.: I'm jealous. -
Other than buying some generic seal material and making it work...the next best bet (I know of) is to goto a wrecking yard and find one better than your's.:-\ -Johnson P.S. Welcome to the board
Subiesport's 1978 DL -- stranded!
[HTi]Johnson replied to ricochet's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I don't believe that it should've been deleted as you suggested. Merely moved(EDIT: I thought he posted in the new gen), as the mods did. As for the problem...I'd start with a compression tester. This will tell you a lot about the engine and will help you diagnose the problem, as you probably know. Good compression? Check spark good spark, check for air. Simple engines require simple diagnostics. -
Step-by-Step Head Removal EA82 Turbo
[HTi]Johnson replied to Pooparu's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Pulling the engine is not as hard as it may look. -
Woh the headgaskets are different? So if I used a turbo gasket on a NA engine, they'd last longer?
+ I'm not sure about over there in Pennsylvania, but meth is illegal here.
Serious leak help fast
[HTi]Johnson replied to DiGiT_xero's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Hello all. I helped reseal this engine. The leak is coming from the driver's side valve cover. It's tight and the seal is there. It didn't leak for a while....then it just started gushing out. The thing is when you now add water it comes out of that valve cover. So, it's probably cracked, but do you think it's the head or the block. Is there an easy way to check? Thanks everyone.
