Hello All
I just put an EA 82 engine back into my cousin's 85 GL Wagon Carb car. I replaced timing belts, idler gear, tensioners and replaced the gaskets on the oil pump. I had my son put his finger over the #1 cylinder spark plug hole to check for TDC on compression. He stated that air was being blowing out of the hole and I checked the flywheel and it showed was lined up with TDC mark.
Well to make a long story short, the boy was wrong and we have the engine already in the car. Is there an easy way to fix this issue without having to pull the engine out again?
thanks
ed
