xman
About xman
- Birthday 01/14/1972
Location
Laguna Niguel, CA
Interests
Rally
Occupation
Engineering Manager
Biography
Amateur rally driver
Vehicles
rallycar, STi, Brat
xman's Achievements
Advanced Member (3/11)
0
Got the Brat seats back from recovering them. We retained the original cloth insert and put new vinyl all around. Also welded the clutch cable bracket at the pedal end and installed a new clutch cable. Now to scour several years worth of accumulated brake dust and grime off the white wheels, paint the plastic bumpers and mirrors and give it it a nice wash & wax.
The sensor switch is bolted to the floor under the console by the hi-lo lever. Mine had the little plastic piece break off the switch when I was messing with the shifter a while ago, now the 4WD light stays on all the time. I'm pretty sure I saw the entire part on Rockauto.com for $12.03 http://www.rockauto.com/catalog/x,carcode,1267725,parttype,10775
Bringing this one back from the dead. The bracket for the pedal end of the clutch cable broke on my 86 Brat. I see that I could get an 84+ pedal support, but do you think it would hold if I rewelded the original one? Maybe a little improved gusseting could make it hold up or is it totally a lost cause? I have access to any equipment to do the job right. thanks.
Lost the clip for clutch cable, pedal end
xman replied to xman's topic in Old Gen.: 80's GL/DL/XT/Loyales...
thanks. the clip I posted above is working fine. I also noticed, while I was installing that clip, that the hill holder cable has a similar clip. Since my hill holder is disabled, I could have just borrowed the clip from that cable and gone on my way. Now I know where I have a spare readily at hand under the hood should I ever need it. Living in SoCal, there are not convenient junkyards around like the rest of the civilized world, and I would have thought it a common item in auto parts stores as well, but every one I went into didn't have it and the parts monkeys couldn't find it in their systems. I'm glad this thread is here now to help others who come across the same issue I had. -
I got myself a hairpin retainer clip that I will try until I get the real deal. like this: I'll swap the one in the engine bay down to the pedal cause I know that will be more solid under there where I can't see it well to check on it. And I'll put the wire clip in the engine bay where I can more easily reach it and keep an eye on it. -
Thanks for the advice on how to pull it out, I knew that, the notes on the photo are not mine. As for pull a parts, they are not so common here in SoCal and to find an 80's Subaru is even less common. I was hoping there was an alternative or someone would have one I could buy. Dealerships here are not so helpful, their systems don't go back far enough to help me. But I'll keep trying. -
It's not just a C-clip, since it is missing, I'm not 100% what it looks like, but it does the same function as this clip which is at the gearbox side of the same cable. I'm ASSuming it could look the same since the washers and rubber grommet thingys look the same on both ends of the cable. I borrowed this pic from another thread by Moosens, but it might help. Again it is NOT the clip in the picture, it is on the other end where the cable attaches to the bedal box. Thanks. -
So I found that the stiffness of my clutch cable is because the retaining clip on the pedal end is missing. Any advice on where to get another or what I can use as a substitute? I was thinking of using a brake line retainer clip but I'm not sure if it is the same size. USMB to the rescue?
Has anyone ever figured out what the threads are on the pipe fitting on the head? I'll gladly cut & hammer shut as GD suggests, but a plug in there of the right size would be nice too.
You can try getting a replacement in the 'Help' brand replacement generic parts at the local auto parts store. the package has an assortment of sizes and shapes. I found one that for in my 93 impreza. Good luck.
