newsance
Everything posted by newsance
Thanks. After further talking with the mechanic, it comes out that he does not have the tool, and was balking at adjusting the valves, because labor for him without the tool would be similar to pulling the heads. We also dicussed that the valve could possibly be damaged and or burnt. The fact that the misfire has become so prevalent in such a quick period of time could mean this. The course of action is he will check clearance, and we will go from there.
My car has a progressively worse miss on cylinder 4. I've done the typical stuff, plugs, wires, coil, cam position sensor, crank position sensor, fuel filter, clean EGR, etc. No improvement- problem is getting worse with milage. Miss mainly occurs at idle, seems to clear up at higher rpm. I took the car to a "subaru specialist" private mechanic, because I suspected the valves were out of adjustment. Mechanic tells me compression in cylinder 4 is off by 15 lbs (similar results to my test), and that it is a valve issue. However, he is saying the do not normally need adjustment and he needs to pull the head and replace the valve. My understanding is that they are adjustable, and subaru has a 100,000 mile service interval to check these? After questioning this, mechanic tells me even if they are adjustable, he needs to tear down the head to reach them and at that point he might as well take the head off to replace the valve. What is your opinion here?
Ok, so for the past month, I have been getting a recurring P0304- Cylinder 4 misfire detected. It typical happens at idle or low load. It seems to accelerate fine. At first it was occasional, but has been getting more and more prevalent. I'm at wits end trying to take care of this. I've replaced spark plugs, wires, coilpack, and fuel filter. I've swapped fuel injectors with a different cylinder- no change. Compression test shows 150 PSI on the cylinder- same as the others (I live at 7,000 feet- the cylinder pressure is typical). I've cleaned out the EGR valve and checked that the valve wasn't stuck. I haven't checked the EGR solenoid because I'm not sure how. I need other suggestions. Thanks!
Actually, I bought another Subaru shortly after this happened as I needed to drive cross country. The only reason I was looking at fixing this was to sell it (and get it off my property). And I am not putting the money and effort into replacing the head, and possibly the whole motor if the pistons are badly scarred. Unless somebody can come up with an explanation that doesn't involve the valve smacking the head hard enough to break a cam, I'm not tearing this motor down any more.
This will be long, but hopefully interesting. I need some engine sleuths to help me explain this one. I'll start with what happened- 1990 Subaru Legacy Wagon AWD Auto with 138k on the clock. I was driving home from a 200 mile round trip. About 50 miles away from home, in an area absolutely deserted, the car suddenly lost power and started sputtering, missing, and smoking, with a lot of lost power. I decided to keep driving it to see if I could make it home, for one, I had bought the car for $750 and a 50 mile tow would cost about half that, so I decided to risk it. I made it about 25 more miles before the car then lost even more power, to the point where it would not stay running in gear. At this point I took my losses, and had it towed home. At first, I was sure that the timing belt had skipped. So, it was to my complete amazement to find that it had not- all the pulley marks lined up perfectly. At a loss for how it was running, I tried a compression check. Surprise! Zero compression on the 2 driver's side cylinders. At that point I was stumped. The only thing I could come up with was a massive head gasket blowout between the cylinders, but if that was the case, I would have had milkshake oil or oil in the coolant, which I had neither. I bought another Subaru and let this one sit for most of a year. Finally, I decided I needed it out of my garage and tore into it to see what was wrong, with the thought of fixing it and selling it. Things I found: ------------------- 1. The camshaft was snapped in two pieces just behind the oil seal housing. 2. All bearing surfaces on the camshaft look fine. It did not seize in a journal, and both pieces freely spun. 3. The camshaft keyway for the cam pulley looked perfectly fine (not chewed up) but there was no key to be found. 4. Rocker arms look fine, and I don't see broken valve springs. Aside from the broken cam, things look normal under the valve cover. ----------------------------- I've NEVER heard of a Subaru breaking a camshaft. As far as I can figure, the only 2 ways enough force could be generated to do this would be if a journal seized, or if a valve got jammed against the piston. As I can't see that a journal seized, it must be valve interference. Right? My temporary hypothesis is that the cam gear could have shifted position on the cam as there was not a key to hold it in place for some reason. This, the car starts to miss and lose power. Eventually it shifts so far that a valve contacts the head, and the camshaft snaps. Problem with this hypothesis- 1. Why did the cam snap instead of the timing belt shredding or skipping? The belt did not jump- it kept the exact same relationship with the cam gears. 2. If the cam gear shifted position on the cam, sending that bank out of time, wouldn't it continue to spin? If it had already started to spin, I don't see how it wouldn't give before there was enough force to snap the camshaft. ----------------------------------------- The main point of this exercise is to see whether there is a point to continue working on this engine or to just junk the car. I'm not willing to replace the head, and I can't imagine the valves would still be working if they smacked the piston hard enough to break a camshaft. What do you think? :popcorn:
Thanks. Ironically I tried it today, and the a/t light didn't flash at startup, so I drove it to run errands. No light the whole day. My guess is that while fumbling around to find the diagnostic leads, I inadvertently reseated a loose connection or the like. Still, its good to know how to do this, and also that if I get a code 16 again, it isn't mission critical and I can keep driving the car in the short term.
I want to make sure I am correct here. I see the black terminal, and I also see in the same area 2 green single wire connectors that in my 1990, put it in diagnostic mode when connected. Are these 2 wires with the green connectors the ground wires, or are there 2 more up there than I need to get free?
No torque bind. I did tight turns both in AWD and FWD modes and don't have any problems. I think I realize what I did wrong. When it talked about entering diagnostic mode, I thought it meant plugging the Green connector together under the dash. I take it grounding pin 5 is a paper clip trick? Anybody have a picture/diagram or good descrption of which on pin 5 actually is, and which is the ground pin?
So, The A/T temp light is flashing 16 times consistently every start-up, starting tonight. I have no drivability issues, and don't feel anything wrong. No torque bind noted. Also, putting the fuse in the FWD socket definitely turns it to FWD, and I get a the FWD dash light to come on. I've tried to get it into diagnostic mode to pull the code following the directions attached to this thread, but it doesn't seem to work. Did something change? Is this an OBD2 car where you can no longer pull the codes from the light? I'm not sure when that changed. http://www.ultimatesubaru.org/forum/showthread.php?t=72486&highlight=pull+trans+code If so, how do I go about pulling the code?
So uh, you realize that Ford FWD transmissions tend to last about 80k? Just go Taurus shopping, and you will see virtually every damn one with a rebuild transmission. You got to 100k, and you have an issue due to your own negligence, and you want to sue the manufacturer because of it? Good luck dude.
Lets try asking this question another way. Look at the bottom of your timing covers. Are they wet with oil? If so, I would do a timing belt and replace the leaking camshaft seals. Given the age and milage of most of these cars, you will probably need to address the commonly leaking cam seals before you have to do a timing belt. The good news is that the timing belt is easy, with the only tricky parts being getting the crank bolt off and depressing the tensioner.
My complete apologies. For some reason I thought that you were fixing this in a mechanic's capacity for somebody else. More power to you for finding a repair that keeps the motor going- if it breaks you are back where you started, needing a new engine, so what's the harm? I'm just shivering at the thought of pulling the timing covers and seeing something like that someday. Not that you would sell it to somebody without telling them, but somebody might!
Pinging!
newsance replied to aartod's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
In addition to the other suggestions, I would note that pinging can be caused by carbon buildup. Misting water into the inlet track will clean the cylinders (and smoke out the neighborhood). -
I'm driving 800 miles each way on the 4th, pulling a jet ski trailer of roughly 1300 lbs. I was going to do this in my 1990 Legacy, but the car either popped a head gasket or worse- no compression on either cylinder on the drivers side. So, I bought a 1996 Outback that has the 2.5. The car runs great. But, as we all know, these are notorious for blowing HG's. Am I setting myself up to be completely screwed here? From what I understand, overheating isn't so much the cause as the symptom, right? Anything I can do to stack the dec on not blowing a head gasket?
Everything related to the timing belts is right. It never showed that it was overheating on the gauge. However, I did remove the radiator so that I could get an impact wrench on the crank bolt when doing the t belt. Its possible that it had an air pocket in the cooling jacket that allowed it to overheat locally and blow the gasket.
