1993 Legacy Airbag Reset
greenieman7 replied to greenieman7's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOK, thank you! Does anyone know how to clear codes with cars with only 1 single wire? I was able to read them with this wire, but as I understand it, there are usually 2 single wires. This car only has one; is there a different trick? Id like to clear and see if they come back. Disconnecting the batt does not do it. Thank you
1993 Legacy AWD Auto Trans 2-3 shift Lag
greenieman7 replied to greenieman7's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe easiest way to adjust it is to tighten it all the way and then back it off slightly. If you get a jerky shift, back it off a little more. The above is quite different than the process described before; I'd like to try it, but want to be sure it wont hurt anything; is it safe? Thank you
greenieman7 replied to greenieman7's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXfeeling stupid but cant find the airbag control module. the drawing makes it look like it is under dash on top of trans tunnel, but dont see it there, no big wire bundles lead there. is it under the shifter center console?
greenieman7 replied to greenieman7's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThank you, but I need to keep this thread on target or drop it. This is a $700 car that I bought in an emergency to get my dog home and now need to resell, but want to insure is in decent shape (if possible). I believe the problem stands a chance of having a simple fix. With this in mind I am looking for experience. The band adjustment was a good idea, but did not do it. I would guess that dropping the valve body and cleaning and inspecting it, looking for a sticky valve or equal might not be a big deal, but I could be wrong. If anyone has any experience with this, I'd love to hear back. Or suggestions of other places to look. Thank you all for your help.
greenieman7 replied to greenieman7's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWith the link you provided, I should have no trouble figuring it out. I will go through it tomorrow and post my results. In the meantime, thank you very much for your patience leading me through this
greenieman7 replied to greenieman7's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAt this point, I don't think it is band adjustment. Slight adjustments made no difference so I went through the process of adjusting it to 6.5 ft lbs and backing off 3 turns. I had to improvise a bit as I could not fit a torque wrench with socket on to the 8 mm square post (too close to firewall). Nothing I did stopped the problem. So I am back to thinking it is either a valve sticking, a solenoid not functioning correctly, or something related. The other variable I forgot to mention (but will mention now) is that on the highway, going up hill, it does not want to automatically downshift. I had/have to manually downshift or it stays in 4th. I don't care about this, but it may be a clue. Thank you
greenieman7 replied to greenieman7's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSo, it is code 14.
greenieman7 replied to greenieman7's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSpec is hard to read in that link; I believe it is 6.5ft lbs, not 8 lbs, but still wondering if this approach is a good one (please see previous post)?
greenieman7 replied to greenieman7's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOK: #1> blue, #2> white, #3 empty, #4>Red/Blue, #5> Black/white, #6> empty. I appreciate your approach. I dont want to blow my head off any more than you dont want to guide me into blowing my head off. Besides all other precautions, I will be well clear of the bag inflation zone at every step. ;-) I have looked again and again, pulled off all electrical tape in the area and still can only find 1 wire, a black wire with white (possibly silver) flecks that meets the description. There are other single wires, but they all have big plastic connectors on them.
greenieman7 replied to greenieman7's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell it turns out that the lock nut was loose; I am not sure how loose as I put a wrench on it, turned it, felt no resistance, then tried with my fingers and it was loose. It may have had a slight bit of resistance that was easily overcome by the wrench or it may have been finger loose to begin with. It had not backed off far as it did not take many partial turns to seat. Question is, have I lost my base setting? I tightened the 8mm head, but didn't want to exceed the 3/4 turn parameter. I am wondering if there is some base setting? Would it make sense to use the directions for 1&4, tighten to 8 ft pounds (Ill recheck the spec first), then back off 3 turns?Is that back off 3 full revolutions? BTW, it seems comparatively easy to get to on a 93 Legacy. Thank you
greenieman7 replied to greenieman7's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXReading the last page of that attachment where it describes the clearances, it describes precisely the symptoms my 4eat is having. Ill try it. thank you
greenieman7 replied to greenieman7's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOK: I did not notice that the diagram in the link said black (otherwise I can not find where black was mentioned before), but anyway, thank you, yes the black plug is right there in front of my face :-) (I was myopically focused on yellow because of it being an airbag system). There appears however to be just one black single wire; the diagram shows 2. I have looked carefully. Unless it is tucked away in an entirely different harness. Is the correct procedure to connect the single wire into the the black wire in the plug, turn the key to on and read code? Thank you
greenieman7 replied to greenieman7's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAre there any existing threads or links to an explanation the band adjustment procedure? I did find a good description of the 4EAT trans and have a slightly better understanding, at least better overview of how it works.Thank you
greenieman7 replied to greenieman7's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI was able to find a single black wire (I believe with white flecks) taped up to the harness, but not 2. My plug is as described above; I am wondering if these differences are because I am working on a 1993 Legacy, not a 1996? Anyway, I I would guess that I plug this wire into one of the wires on the yellow connector, likely the brown/black/red one, then turn the ignition key on and read the codes, but I would like to be sure. Very sure! Thank you
greenieman7 replied to greenieman7's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThank you. Just out of curiosity, are these solenoids true electrically powered solenoids? Can they be checked electrically by measuring resistance? Anyway,, thank you
greenieman7
