Injulen
About Injulen
- Birthday 09/04/1990
Contact Methods
Website URL
http://www.injulen.com
Location
Augusta, Maine
Occupation
Plumbing & Heating
Vehicles
97 and 95 Legacy L Wgn
Recent Profile Visitors
Injulen's Achievements
Advanced Member (3/11)
Thanks for the advice! I'm actually starting to think about other things I want to do to the car now and a nice throaty but not loud muffler is on the list. What you described sounds EXACTLY like what I want. I've currently got Michelin Defender XT tires which seem like they'd be excellent for MPG. I've got synthetic oil in the EJ22 now, and the gear oil in the rear diff and 5MT is on my list of things to do soon. Any recommendations on which fluid I should look out for? I'm not sure if I want to lower it or lift it haha. Stock height for now is the best of both worlds I guess A 1-2" drop would look good, just swap in some WRX suspension I think is an easy way to do that. 1-2" lift is about all I'd do and isn't nearly as noticeable as a bigger lift which is what I'd really want. Maybe I will actually lower it haha. Pic of my wheels and tires: https://i.imgur.com/S8iItfC.jpg
Update on mpg. Most of the time I'm running 24 to 25 but on a good tank without a lot of city driving I'm hitting 28. Best yet was 28.6. I've rub 87 and 91 octane and haven't noticed a difference. I'm going to pull and check the spark plugs this weekend. I'm loving the swap still! It's great seeing the reactions at meetups when I say I just finished knocking my HP down 30 ponies and love it more after.
I can definitely tell the 2.2 had more low end torque now after driving it 300+ miles. I can also chug along at lower rpm easier without the engine feeling like it's lugging. Sohc ftw! I do think I had some pinging going on with 87 octane. There was an odd noise I thought was my heatshield but it was too regular and consistent. Put 91 in and it stopped. My torque app has a knock detector mode and it passed 100% with the 87 in there but since the sound went away with higher octane I think it was detonation. I haven't redlined it, I never do. Also can't calculate mpg yet cause I have to fix a fuel vent line that leaks when the tank is full. But if anything I think I'm getting better mileage or at least very close to the same. No emissions testing up here in my county of Maine so no worries. Got a fresh inspection sticker after the swap without issue. Mechanic and I talked all about the swap and he was impressed with the condition of my 241k mile 1999. Once I fix the fuel vent line I'll update here on my MPG.
I can probably do a logfile of my timing advance if you'd like. Good point on the DOHC vs SOHC difference, that would explain how it feels. I have a steep hill by my house and with the EJ25 I used to have a hard time turning onto that road in 2nd gear and getting momentum built up while climbing the hill. It was to the point where I'd slow to a crawl during the turn and hit 1st gear just to get some oomph to climb the hill. Now I can stay in 2nd gear and have plenty of power to get going. Also..
That's actually funny, I stopped have shorting and arcing problems after I took the positive strap off the starter while finagling that bellhousing bolt. I must have re-installed it in a better manner! Just got done putting on the new shorter bellhousing bolt which allowed me to utilize the stock starter ground strap location again. Now it starts and runs perfect without jumped cables to aid the grounding! Also it DRIVES perfect! I barely even feel like it's less powerful, I imagined a 30 HP drop would be much more noticeable. No CEL after several miles, OBD-2 passed most of it's self tests sans the ones that take a long cruise like the evap. Idling right at 700 RPM, vacuum is reading a "9.3" but I have no idea what is normal.
I have just done even more research and continually find information stating the 2.5 ecu can run a 2.2 perfectly as well as vice versa. It's the nature of the o2 sensor feedback loop, it just measures the exhaust gases and adjusts the air to fuel ratio accordingly. There is no reason to think the 2.5 ecu will ever cause harm or even consistent rich conditions. The ecu learns and modifies it's behavior to match. The ground strap is still an issue but I've been diagnosing by using jumper cables from the negative terminal to the starter body. I'm going to tractor supply to get the proper length bolt to put through the bellhousing to attach the starter ground strap tonight. The bolt I thought was ready to shear off ended up coming out just fine.
I have just done even more research and continually find informArion stating the 2.5 ecu can run a 2.2 perfectly. It's the nature of the o2 sensor feedback loop, it just measures the exhaust gases and adjusts the air to fuel ratio accordingly. There is no reason to think the 2.5 ecu will ever cause harm or even consistent rich conditions. The ecu learns and modifies it's behavior to match. The ground strap is still an issue but I've been diagnosing by using jumper cables from the negative terminal to the starter body. I'm going to tractor supply to get the proper length bolt to put through the bellhousing to attach the starter ground strap tonight. The bolt I thought was ready to shear off ended up coming out just fine.
Thanks for the advice. The grounding issue I've just about taken care of now, the problem electrically I'm having now is a phantom draw. I don't think better grounding will help that, I have to find a short of some kind. As far as the 2.2 ECU, I found on numerous sources (including this forum) that the 2.5 ECU will run the 2.2 no problem, it's a direct plug and play swap. If I can't figure it out soon I'll try swapping the ECU too but that really shouldn't be the problem. Oh and the "random surges" aren't the ECU, that's my foot on the throttle. If I just let it do it's own thing it drops the needle below 500 and sputters and dies. I was giving it throttle to keep it from doing that, just for the sake of the video. I haven't repeated this since. I'm still hoping it was the IACV being stuck that caused this and I've now swapped another one on but the phantom draw and lack of working starter is where I'm at now before I know if that swap helped anything.
I think I've got the vacuum lines sorted now. An oddity though, this is the only Subaru engine out of six that I have which has two nipples for vacuum lines on the passenger side rear of the intake manifold. All the others have a plug in the lower hole. Not really that relevant but I found it interesting. Anyway, here is an actual link to the video for you: I've swapped in a different IACV since I thought that might be the issue but now my electrical problems seem to be worse.. the battery is draining fast when left hooked up and when I turn the key forward, I have plenty of juice for lights and windows but then when I put the ignition to start the check engine light loses brightness and gets really dim. The rest of the lights stay on fine. I can get a few cranks out of it but then it goes flat. I've tried a different battery and unhooking the alternator and it's still doing it. I can't for the life of me figure out how I could have caused such a bad short in the wiring but that's what it seems like to me. At this point the starter is having issues too, it now won't even crank at all. I guess next step will be to get that swapped for a known good one and see what happens. Edit: Okay, no matter what I do to put in that youtube link it keeps automatically embedding the video. I can't even paste the link as plain text. Grr... I'm going to put it here without the prefix so you can copy paste it hopefully. youtube.com/watch?v=pgXEFEu6qHw
