Soobie-ruu
About Soobie-ruu
  • Birthday 03/20/1991
  • Location
    Spokane
  • Interests
    rc racing
  • Occupation
    McDonald's
  • Vehicles
    1980 subaru wagon, 1979 S
Soobie-ruu's Achievements
Advanced Member
Advanced Member (3/11)
0
  1. I love that white three door Scot. Never has left me nowhere
  2. I have power on both sides of the coil but none going from the coil to the distributer
  3. I'm having the same problem no spark from coil coil bracket has been replaced and so has the coil what els could it be
  4. The welding term used with sheet metal is called "stacking dimes" so you don't warp the sheet metal, in auto body they teach you to do a small weld like a circular tack weld every ten inches. Then wen you get to the end you start at the beginning so it allows Time to cool
  5. can you please email it to me im doing the conversion right now and want to know if im doing it right, quintan.gordon@gmail.com thanks
  6. wen i turned it over by hand it wasnt a smooth feeling i could feel something was wrong, i pulled a head and a pston would move up and hit a spot and stop moving up and hold in the same spot about half way up the piston, idk what could of failed, i havent really heard of a throwin a rod in a subaru cuz there short and stubby, could the piston broke where the wrist pin attaches? idk i might split the case, or try to get the broken piston out and figure out wat happened.
  7. ok so what i thought was wrong wasnt, but i was trying to be optimistic. i got it out and turned it over by hand, but i can feel that a piston is dragging so im pretty sure its toasted. idk im thinking of just getting a gasket set and regasketing my other ea82 any suggestions or ideas?
  8. ok so i was thinking about calling and seeing if a foreign engine importer has any subaru diesels, if one could be found is a different tranny used, and if so how hard would it be to come across?
