wisdomwrx
About wisdomwrx
- Birthday 10/16/1990
Location
Murphys, Ca (209)
Vehicles
80 Brat GL, 03 WRX
wisdomwrx's Achievements
Member (2/11)
0
So I finally found a good thread will read up and post questions if I have any.
I tried to look for a thread showing someone doing a swap but could not find one. If someone could help me find a good thread on the swap I would be very thankful. Ryan
Ok, so I own a 1980 brat gl ea71 4 speed manual 4wd. I have the know how and skills along with tools to do a swap. I am pondering on doing an ej22 swap for an early nineties subie. How much work am I looking at. What needs to be changed to allow the swap do I need to make special drive lines to fit in the smaller vehicle? Also do I need to make new motor and trans mounts? Will the newer rear diff bolt in? I'm just looking for some info about this swap specifically. Any know how or tips will be highly appreciated. The reason I am wondering is because I just want more power, I live in the sierra's of northern Cali and the brat barely has the power to keep up speed due to the fact that everything is hills and corners. Thanks Ryan
In need of some wiring diagrams
wisdomwrx replied to wisdomwrx's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yes it is running and driving great. -
CHG light on gauge cluster?
I know it's not serviceable, but is there anyway to check it. Like find out if it's broken. And then lastly do you have to resolder the switch when you get a new one, or does it come with the wiring to the connector? -
Well since the battery and alternator are good I'm gunna go with either ignition switch or bad wiring to the dash. Anyone know how to change/check the ignition switch? It looks like all the wiring to the switch is soldered into the switch. -
Well I think you may be right. A couple questions though. If I hit the top of the dash sometimes it makes it come back on. And secondly will the ignition switch start the engine even if it has become bad? Thanks Ryan -
Older wheels... New paint
wisdomwrx replied to 92_rugby_subie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Either take them to be sanded blasted or be prepared to take some time sanding! Every rust spot needs to be to shiny silver again or the paint will just pop off within two weeks or so. I have spray painted quite a few rims now cause I did rally cross for a while, and trust me you will probably want to keep them after you put all that effort into them. Cause they will look good when they are done. -
Ok, so first of all what is the CHG light? Is it a Check Gauges light? Cause all the time I have to sit there and restart my brat because that light is the only light that will turn on and none of my gauges will work. So i keep restarting the car, by starting i mean only to the on position on the ignition switch, until the gauges work again. Any ideas on what could be causing it? I checked all the wiring and everything looked fine nothing loose and nothing frayed or broken.
Dam, I screwed that whole post up. My bad, I was really irittated and annoyed. -
Well it runs. Out of no where it starts. I went out to the car to check resistance on the ignition coil, it was ok. Then checked the resistance on the pick up coil, to do that I went to the closest connector for just the two wires that come out of the pick up coil. Found the connector and checked resistance on the two wires at the connector found good resistance put the connector back together and looked around for a little bit and really did nothing. Went back into the car cranked it over and it started right up. But the only weird thing now is that it hickups not consistently, but I am pretty sure it is because of the gas I put in on accident was mixed with 2 stroke oil. So gunna try to burn the tank out tomorrow and go get a new fuel filter and then put some 91 octane in it. Thanks for everyone's help!! Ryan -
Fuse are all good. And also while cranking, voltage on the coil goes down to 9.5 volts. Ya, that's why I'm trying to get wiring diagrams cause I want to figure this out. I live on a 100 foot cliff so pushing it off a cliff isn't hard lol -
Need Help ASAP! Ignition System problem
ok, so i checked all the wiring connectors from the battery to the ignition switch and then to the coil and to the disty. everything was connected. now im just trying to find wiring diagrams so that i can start trying to test the system. thanks ryan
