3
Everything posted by superpoo93
Go to main page Ultimate Subaru Repair Manual-The Knowledge Base of USMB. Complied posts and writeups to common problems and projects. Off Road mods
Really !!! Your going to scap it because of a clutch and alternator issue??? Really!!! There has to be someone that can help, unless there is massive rot, please don't take to the junk yard..... Sadness. I see too many older Subaru' s in Vegas yards intact and restorable. I cried when I saw a 88 gl-10 sedan last week, and it was a Flat 4 members car, which made it even worse..
Can my 93 Loyale EA82 have died?
superpoo93 replied to myhilo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yes non-interference engine. I bought my water pump from Autozone no problems 60,000 miles later...works perfect. Rock Auto has quality material, with that said... I bought my TIming Belt kit off EBay before knew of ROck Auto. You can take off oil pan, but you have to raise engine up to do so. I would drain oil, and see if any metal comes out first. You said the left side belt broke, was it the drivers side??? If so, I would not worry about the engine, since it would have died quickly, just get a timing belt kit and start her up. -
Are you sure the engine mounts are good? You loosened the cross member bolt and jacked engine up? I thought mine were good too... Till I took the weight off them... Both were Trashed!!
- 38 replies
- 1991loyale wagon
- axle
(and 2 more)
Tagged with:
EA82 Excellent -> Dead (turns over) Help!
superpoo93 replied to Bekokatt's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I forgot to ask which distributor you used when you did the engine swap. I assumed that you used the one from the Loyale, but you probably used the original.. -
Check the rotor....the screw can back out and be sitting on the top. Rotor will still turn, like all is good. Pull up on the rotor -
Bushings my kingdom for bushings
superpoo93 replied to CarpeNoctem's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Hi, I was curious, was Amir able to help you out? -
Amir, @ outback is awesome!! He has owned Older Subaru's : I forgot to mention these are Super Pro bushing. -
http://obtusa.com/shop/page/about?sessid=cKiWrfKtz8ryzpP4823wj0ybYXn1qaE2eBgEhRGd6MXvAqn6QjMSaKOrMaqqQvMt&shop_param= -
I found this also price is much better. Around $60 http://www.subarupartslive.com I cleaned mine and adjusted it works great.
Now here is another option if cleaning does not work. http://www.tristarrradiator.com/
Sorry, I always forget to mention they are SuperPro a distributor.
- 13 replies
- control arm
- control arm bushing
(and 3 more)
Tagged with:
FYI, here is a great source. Outback Technolgies USA they have Polyurethane Suspension Bushings http://obtusa.com/ Here are some part numbers for ref, the pricing is about 2years old and please double check part numbers with them. Ea82 control arm kit SPF1691K. $35+shipping Trailing arm complete bushing kit SPF1144K $89+ shipping I purchased control arm bushings for my 93 Loyale, 2yrs ago. Bushings are polyurethane . Amir is awesome, has owned older Roo's, and has good pricing. I made my own tool to push them out/in, piece of cake. I will try to find the pictures of what I used. 2986 Navajo Street Yorktown Heights, NY 10598 Amir Web Outback Technologies Inc. 28 PO BOX Yorktown Heights, New York 10598 US 914-302-2431 914-214-8230 sales@obtusa.com sales@obtusa.com
- 13 replies
- 1
- control arm
(and 3 more)
Tagged with:
ea82 control arm bushings
superpoo93 replied to 2.5LOYALE's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I know this is a little late ....but Bushings are polyurethane . Amir is awesome, has owned older Roo's, and good pricing 2986 Navajo Street Yorktown Heights, NY 10598 Amir Web Outback Technologies Inc. 28 PO BOX Yorktown Heights, New York 10598 US 914-302-2431 914-214-8230 sales@obtusa.com sales@obtusa.com -
Any suggestions on where to get parts from?
superpoo93 replied to pablo83's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Oh forgot these are polyethylene bushing. OMG, it was awesome to have new control arm bushings!!! Amazing how worn the old ones were. Hope this helps -
Call Amir @ Outback Technolgies, he is very knowledgable. He has owned older Subaru's. 2986 Navajo Street Yorktown Heights, NY 10598 Amir Web Outback Technologies Inc. 28 PO BOX Yorktown Heights, New York 10598 US 914-302-2431 914-214-8230 sales@obtusa.com sales@obtusa.com -
RF vibration when turning at speed
superpoo93 replied to rrgrr's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Does seam to understeer ?? I had a issue where I had vibration and clunk while driving.. When turning fast, it would push to the outside...like it was sliding. It was loose bolts connecting strut to the knuckle. Check bolts make sure they are tight, then look for other issues. -
I agree with you Mr Loyale, if its not broken ...why fix it. It's your choice, it's easy enough to go back in later, and change them if they start making noise.
I still had noise after changing oil pump. Mizpah was the way to go, no more noise. If they don't have lifters to buy, go to junk yard and pull nice oily ones from a donor and ship to them... I think it took a week to get them back.
