firstsubi
About firstsubi
- Birthday 05/30/1988
Location
chester county
Vehicles
loyale
firstsubi's Achievements
Advanced Member (3/11)
5
And I had the timing belt done with new water pump about 50k miles ago and asked them to change out cam and crank seal while they were doing it and they told me the seals look pristine and no need to change them. They said let it go another 100k until the timing belt needs done again. I was mad when they told me cam seal because I told them I wanted them changed out. I didn’t want to be on the hook for a $600 seal job that didn’t fix the problem if I want going to have them do the head work
I agree! This service manager also tried to tell me my strut tower was bent and that “any trained eye could see that it’s bent” and I told him no it’s not. Took it somewhere else and it wasn’t bent. I just take my car there because they give me a loaner and I’ve never had a problem with their work but this seems to be a foul diagnosis costing me $2200
No accident. Motor is fine I was driving down the road and it started leaking oil but I pulled over before the oil light even came on.. I was thinking that too about making sure it’s messed up since they know I want to have it now. But he told me it didn’t wobble at idle but when you give it gas it’s off?? I’ll put up pictures when I get the head back and take it somewhere else as well!
I have a 2010 legacy 2.5i m/t 167k miles, car never leaked a drop of oil until last Friday it started leaking bad! and smoking.. I pulled over to see what was going on, it was still running fine and no lights came on. Couldn’t see where oil was leaking from so decided to have it towed to the dealership. They said I was a quart low (I just did oil change 3 days prior) so it leaked a quart in about 30 min. They told me they topped it off and added Uv dye, let it idle for 20-30 checked it and couldn’t find any leak, told me to pick it up and drive it for a week and bring it back so they could check again.... picked it up got 2 min down the road and it’s smoking and leaking again so I took it back and within 5 min of them getting it back they are able to tell me it’s the driver side cam seal. ($600) I said alright fix it, then they call me the next day and tell me that I need a whole new head because the cam is “out of round” $2200. The car ran fine with no lights on... has anyone ever seen a n/a Subaru bend a camshaft and wear out the head? I just can’t believe it but told them to fix it if that’s what it needs. ????
Pulling front right spark plug
firstsubi replied to firstsubi's topic in Old Gen.: 80's GL/DL/XT/Loyales...
So take the belt off and swing the compressor out of the way? -
I bought a normal 13/16 deep socket (maybe the sockets too deep) but I can’t get it with just the socket and an extension or an extension with a swivel.. its really just the bracket for the a/c in the way. Guess I’ll swing it out of the way. I can get the socket on but then I run out of room. -
Just bought a 90 loyale last week and want to change the plugs.l, I got the three easy ones but the one in the front right is terribly hard to get at. The ac compressor is blocking my access and I was wondering if there is a truck to getting to it. Do I really need to remove the ac compressor? Thanks!
Complete Cone Washer Failure
firstsubi replied to jj421's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yes the domed side goes towards you, the newer ones are marked with "out" but I just picked up two sets of wheel hub hardware and the one nut was marked on the right side but the other said "out" on what was really supposed to be "in, so always just look for the convex and put it towards you -
stripped 10mm valve cover bolt?
OK. As long as the hole has something in it stopping the oil from blowing out I should be ok? I'm looking to get a newer car within the next month or so. It's an ea82. With a Helicoil isn't it necessary for me to drill the hole out?
