2
Everything posted by scoobyclimbs
I know wrx alloy 16" wheels are 55mm offset Stock outback alloy 16"wheels 45mm I have Konig incident 15" with a 40mm offset
I christened the foz while hunting for a campspot @ Mt.Bachelor foothills. I stumbled on some kewl back roads to test the foz out. I was fully loaded @ 3750lbs. Skis, ski pulk, camp gear.. I brushed the foz abit , then took the foz for a dip... click on the first pic for video.. My kinda trail bushwack...! Yes I did drive over that...those that know me well...
That's a "Scooby snak" lol
For Oregon trail rally I had to find the perfect spot to park... Finally got the Foz dirty...
I was getting 25-28 on my lifted ej22 hatch..I use my gps to calculate mileage for distance traveled.. I could get better if I stayed off the skinny pedal...my addiction to boxer rumble at WOT...is just too tempting...
How many of you will bring off roaders to WCSS this year?
scoobyclimbs replied to ezapar's topic in Off Road
I'm down.. 2" lifted forester w/ m/t, lsd 4:44's ..should be ok...? -
Anyhoo, nice looking addition to the lineup, which one does the wife get? She has a 07 mazda 3... Were looking at new impreza..maybe a BRZ..."honey can borrow the car to go get ya some wine....."Three hours later ....
I noticed a bad vibration and seemed the timing was off..The front crank seal was leaking so it was time to check it out. First off the crank pulley bolt wasn't even tight ..! The damper was damaged FUBAR.. The woodruff key was rolled over..! I had an extra dampner on hand and the crank, gear were ok.. It had throw the timing off about a tooth w/ missfire codes on cyl. #1, #2.. Alot of miss information out there on crank pulley bolt torque. Subaru recommends 130ft lbs. The good news is I saved it and runs perfect now...
I retrofitted my primitive front skid plate from my outback to fit the foz.. It's only a temporary so I can save for the lift.
The first mod... I installed the cb ...
I picked up a '98 foz S model , 2.5l, 4eat, lsd. The plan is to lift it , mud terrains, cargo basket, lights ,Primitive skid plates, Primitive offroad bumper w/ winch.
H6 100amp alternator on EJ22 swap
scoobyclimbs replied to scoobyclimbs's topic in Subaru Retrofitting
That would be nice. However, as I stated previusly . The h6 alternator is bigger and the pulley cannot be swaped. I did try this already. -
Here's a link with Cmiller's swap pics on pg. 2 with pics.. http://www.ultimatesubaru.org/forum/showthread.php?p=1092619#post1092619 Nice and clean drop in Chris..
On Sat, I helped Cmiller do the swap witha a 90amp ej25 alternator. It was a cleaner install given the pulley was the same and no modification to the plastic coil/tb cover. Cmiller will add the extra wiring and fuse to the battery later. A side by side comparison of the ej22 alt. below, ej25 alt above. It is a drop in install. Note: we cut out the long alt.mount bolt(between the two mount ears) and relpaced it with two smaller bolts and flipped the front bracket nut to the backside.(this way you don't have to remove the radiator to change alternators.) Here's what you'll need (about a foot of harness w/ plugs) they are labeled with what color you splice into the ej22 harness. ej25 ends Blue w/ red stripe goes to ej22 black w/white stripe. ej25 black w/yellow stripe goes to ej22 yellow Cut the third heavy gauge white wire from ej22 alt plug off at the 3way junction. Splice the two large white wires together and the other ends mentioned above. (solder all joints and use butt connectors/heat shrink). We used a 1/4" 3/8 eyelet (cut out the eyelet and slide the two ends in and solder each end and crimp.) Notice the perfect alignment w/ the 90amp ej25 pulley.. The h6 alt. is slightly bigger therefore requires more modiction. -
I found that all the h6 alternators (ez30) were only 100amp not 110amp . Perhaps a later generation or h6 3.0 or 3.6 has a 110amp. -
scoobyclimbs replied to 6 Star's topic in Old Gen.: 80's GL/DL/XT/Loyales...
my '84hatch and team cf's '83 wagon -
Next time you head out that way let me know ..I've been going out there since 1990...I know about every trail out there... Mt.Defiance has some of the best..Middle mtn. , Surveyors ridge...etc..
Why a new crush washer ? I've reused about a thousand crush washers on about every make and model of car/truck heavy equipment..etc. since the mid 80's...never had a problem... If you hit it that's another issue.. I haven't lost a motor yet . Unless it's damaged reuse it.
looks like post canyon in hood river? We head a great time in the coast range snow and then sand lake..
I got some cheap ebay projector headlamps (h4) for $28 plus they have a blue 194 marker which is kewl.. Team cf gave me the hella wiring conversion connectors..
Were headin' out sat round 11am at newberg fred meyers(fuel station) Mt.Hebo camp / sand lake on sun... call me 503-314-7535
