abeattie220
About abeattie220
- Birthday 02/20/1986
Location
Snoqualmie Pass, wa
Occupation
Diesel/ Heavy Equipment Mechanic
Vehicles
02' Forester, 95' impreza
abeattie220's Achievements
Member (2/11)
0
Its got a nasty rattle that i think is the main output beearing, and the right stub is getting sloppy, and would love to not have to worry about it for a while, dont plan on ditching the car till its totalled. Too much effort put into the whole thing.
I have a 95' Imp with an 86' DR 5-spd. The trannys about to role 400,000 and im wondering if its worth a pre-emptive rebuild this summer, or go find another one, or see if my local shop will do it? I have 0 experience with the inner workings of a transmission. Also anyone know if it can be beefed up a little for the extra power output of the 2.2, other then bigger stub shafts? Thanks!
87' GL DR tranny into 95' Impreza?
abeattie220 replied to abeattie220's topic in Subaru Retrofitting
yah the tab isnt there on my impreza just like a recessed square drive and we are up to almost a thousand miles with no reportable issues other than no speedo/odo LSRD is amazing for gettin it on snowy roads -
mine has a cable and the ea trans has a female cable twister thingy and the imp has a female cable as well it will screw into the hole but i dunno if it will doin anything have to investigate -
reworked driveshaft came in today installed first test drive went great snowy roads. have some bugs to work out like speedo cables bein diffent and the torque stopper but all in all drove pretty good -
sweeet thanks man -
anyone know the pin number and wire color of a 95 impreza ecu AT/MT identifier wire or have an ecu schematic for for that yr -
right now i have the auto inhibitor switch wired in and in the neutral position just so it will start for now but eventually im goining to jumper it and eliminate and replace with a clutch start switch on the dash -
almost done just waiting on custome drive shaft LSD installed and front axles spliced (by me) -
so trannys in engines in but it wont start with the ignition totally dead stick it will fire right up if i jumper the starter strait to battery and stay running but at 2000 rpm i have the park switch jumpered out and i know i need to ground the AT/MT pin on the PCM but im still not sure what one it it is and is this whats causing my no ign start and high idle condition? also i just got it in and only had the head pipes on it so no O2 sensors or back pressure i dunno if that makes a difference -
i got one of them but i can take it out and it will run and everything just fine anyway to get rid of the light if it comes on -
'93 Impreza with EA Dual Range Tranny
abeattie220 replied to Rallywagon's topic in Subaru Retrofitting
im in the middle of swapping an 87 dr tranny into my 95 impreza no real headaches so far check my thread for pics tranny is bolted in car in middle of engine rebuild -
im in the the middle if converting an impreza auto to an 87 DR 5spd fairly strait forward so far but its not a daily driver just a toy
anyone know what will happen if i just plain remove my airbag control module. will the air bags just not go off ever or will they develope a mind of there own? -
