3
Everything posted by desertsubaru
What a shame that Subaru has gone so far down hill from 20 years ago. It would be interesting to see what country they were built in because it seems like the cars built here in the states have bad quality control. Quick google search shows the cars in question were built in the USA. http://www.stanleysubaru.com/blog/2013/may/8/where-are-subarus-built-where-is-the-subaru-impreza-built.htm
Sounds like the shift linkage broke or separated at a joint.
- 4 replies
- clutch
- transmission
(and 3 more)
Tagged with:
I am no expert on transmissions but IMO the electronics that control it are probably different.
- 2 replies
- transmission
- auto
(and 2 more)
Tagged with:
Get OEM or Stant super stat. Do not use cheapo stats.
- 31 replies
- Overheating
- Radiator
(and 2 more)
Tagged with:
I have a Gauge and a light. Gauge goes all the way up then light comes on. Also checked with voltmeter and there is an over charge to about 18 volts. When it first happened after fixing hose the gauge stayed pegged on high with light on. Then I drove it home and let it sit for about an hour. I then went back out to start it to move it out of my way. When it started and idled normal gauge was normal and light was out but after revving to above 1500 rpms the gauge shot up and light comes on, when rpms drop it is normal. I am not driving car now and will let sit for a few days to see if it drys up, If not I have another alt I can put on it.
Was cruising along in my 2003 Forester when my top rad hose blow spewing coolant all over the place soaking the Alternator. now at an idle the gauge reads normal and battery light is not lit. At higher revs gauge goes all the way up and light comes on but then drops when rpms drop. So what is you guys and gals opinion on this? Did it just get the internal regulator wet and shorting it out which will cure itself when dry or am i going to have to get a new alt?
If you have access to a wooded area cut three hardwood trees 3 inches around and 12 feet long to make a tripod then get a 1/2 or 1 ton chain hoist. Tie the three together with a good strap then put two legs of the tripod on the fender sides of the car and one in front. You only need to lift the engine a few inches and slide it forward about 5 inches to get to the clutch. Take the radiator out first to give the engine more room to go forward. Also unbolt the exhaust from the heads.
