3
Everything posted by desertsubaru
Can I plug the EGR port?
desertsubaru replied to thedoctor's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Your going to get a lot of different opinions on this. Some will say yes you can plug it others will say its necessary dont plug it . I personally have done it a few times with no ill effects. -
Carburetor EA82 engines 1.8
desertsubaru replied to crazily's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Welcome A name off the carb would help, Probably better off going on Ebay to get a Weber 32/36 and a Carb adapter plate to mount it on your EA 82. Do a search on Weber swap on this board as there are tons of threads on the subject. -
Salut si bine ati venit! Aceasta este o maşină frumoasă.
I'm sure someone here knows a little about them. Stick around this is a great forum with lots of great people. I to like Romy AK 47s and sks
Would like to see Photos of it if you can. I cant help with the problems you have but it sounds like a neat car. By the way I own a 1954 Romanian Mosin Nagant M44 rifle. It is my favorite firearm in my collection.
Weber carb for my 87 gl?
desertsubaru replied to Moosen's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I and many other people have their disty hooked directly from the port on the weber without going through the Thermo switch and they run fine. Every weber on a sube I have ever had was hooked like that with no problems. The EGR may need it but the disty does not. -
Also use a piece of white chalk to mark the flywheel at 11 BTDC so when the light hits it you can see it better. -
Looks like I have a bad headgasket...
desertsubaru replied to shadman's topic in Old Gen.: 80's GL/DL/XT/Loyales...
ME too:banghead: -
The hose that comes from the Radiator on the drivers side goes onto a steel pipe that goes into the water pump that is where that O ring is located.. -
Here ya go. http://www.ultimatesubaru.org/forum/showthread.php?t=126868&highlight=head+gaskets I did it on my EA82 and it worked great. -
Looks cross threaded to me.
Did you drink to much when you wrote that. LOL:drunk: Those empty bolt holes have nothing to do with his problem. You can clearly see that the EGR pipe is not threaded in thus causing a Vacuum leak and also expelling exhaust gas around the threads.
88 gl automatic transmission problem
desertsubaru replied to dmcluen's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Mine is bent like that. Park is between P&R R is N, D is 2. -
That is the EGR tube. Tighten the side thats on the intake because its causing an intake Vacuum leak.
EA82T Studder/Cut Off
desertsubaru replied to tundrabrat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Check the connector on the CTS first. They are known to get corroded and not make proper contact. -
conversion to weber carb, how too!!?
desertsubaru replied to wilcox's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Welcome! Probably the second most ask question on this board. Use the search function and you will find 100s of pages on the subject. -
Happy Easter from W.V Where Subaru's are few and far between.
Try tightening the axle nut more. Breaker bar with a 3 foot pipe and stand on it, Jump on it if the cotter key doesn't quite lines up with the next slot in the nut..
Can U Bypass Bad Headlight Switch ?
desertsubaru replied to roadsubiedog's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I leave my light switch on all the time and my car starts with no problem. -
Since the ignition has to be on for the lights to work then it should only be a matter of temporally jumping the right wires for them to stay on while the car is started. -
EA82 coolant temp sensor???
desertsubaru replied to MR_Loyale's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Check the O ring on the pipe that goes into the water pump. -
Weird EA82 oiling problem
desertsubaru replied to Beladona_13's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Thats why silcone should not be used anywhere near oil. -
Lost the clip for clutch cable, pedal end
desertsubaru replied to xman's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Take either a chisel or flathead screw driver up against the bent piece on the left in the photo and hit it with a hammer. Or get a pair of vice grips on it and pull it off. -
Rear CV axle question
desertsubaru replied to SmashedGlass's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Did you check the Universal joints?
