3
Everything posted by desertsubaru
Great fix! I had an 82 Subaru GL and the fuel pump quit 30 miles from home with no way to contact anyone. I used the windshield washer pump, some wire and a piece of fuel line from the trunk and rigged it to the fuel line and carb. To fill the carb you hit the button for the washer pump. It worked great, every few seconds you would have to hit the button but not only did I get home I ran it like that for a week until I could get a fuel pump.
My 96 obw auto does the same thing. Its like it gets confused of what gear it should be in. No slippage or anything like that just strange shift times and not a good kick down for getting on the highway. It was just checked,drained, flushed and refilled. I thought it was maybe because of a 2.2 in place of the 2.5, but since you had the same thing with a new car it just might be that since I was use to driving a 5 speed and then going to auto im not use to it yet.
96 obw, The 86 had to goto its final resting place Harrys upull in Hazleton. I'm not the average person I have been working on cars for 35 years now but I don't mess with A/C much. I have access to gages from a Friend that works at a shop. The gage shows the the right amount. Thanks for the link unibrook! It has no leaks we checked with the die you put in it. The line from the compresser to the cab does not get cold and the one from the condenser gets super hot.
They said it ran but had a miss, I figured bad plug but seen when I got it home that the wires and plugs are brand new ngks. I think my tensioner piston is bad because it wont move in. I don't have a vice but I do have an 8 inch C clamp, will that push it back? Also how far should the tensioner piston come out when you remove the tensioner? Mine only came out about an inch and I was able to put it back on the block with the tensioner pulley in place, Should I be able to do that? Thanks for the help everyone!
I know a hand crank test isn't accurate but It was getting compression in 1&3 but zero in 4 and a little on 2. As I said I did a leak down test with 4 at tdc and it pushed the piston down enough to toss my ratchet off the crank. Doing a rudimentary leak down test I could hear a lot of air from intake and exhaust, when I crank it it got quieter but was still leaking a bit in 4&2. This engine did sit for a about 2 months. I have the intake off and just went with a light and looked at the intake valves and they look fine couldn't get under it to look at exhaust valves. I then took a little light saber thingy I have that is a light and put it in the spark plug hole and turned the engine until the valves closed and I could see no more light. When they were closed the crank timing mark is way past the timing scale on 4. Shouldn't 4 be on the 0 mark with the valves closed? I will take timing cover off tomorrow and see if it jumped. This engine is really clean inside with very little carbon build up in on the pistons and none on what I can see of the intake valve seats. The car looked like a little old lady drove it to work on Sundays it was that clean.
