Wayback
About Wayback
- Birthday 07/05/1963
Gender
Male
Location
Bothell, WA
Vehicles
92 Loyale, 03 WRX, 94 Legacy
Wayback's Achievements
Member (2/11)
3
West Coast Subaru Show 16 Photo Thread
Wayback replied to Vegablade's topic in Meet n' Greet. Your USMB Welcome Center
http://www.electricsubaru.com/ -
I once forgot to release the fuel pressure before pulling an injector, and didn't notice fuel was running down the hole until the area below filled up and fuel started spilling out of the hole. I think I got lucky and the intake valves were closed, so I was able to stick a tube down there and suck out most of the gas. Sounds like this might be what happened to you, except the intake valves were open and the gas ran down into the cylinder.
- 18 replies
You should NEVER disconnect the battery while the engine is running. It can dump a massive voltage surge into your electrical system. http://en.wikipedia.org/wiki/Load_dump
- 11 replies
- power loss
- check engine
(and 2 more)
Tagged with:
EA82 Fan Power Selector Fix
Wayback replied to ystrdyisgone's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You can still get a new blower resistor pack, costs about $40, part# 72083GA070 -
The compressor in that pic is not original equipment. No 90's Legacy A/C compressor had more than one connector (or any connector that looked like those), or a "revolution sensor". The single wire is for the magnet clutch. The part with 2 wires is a thermal protection switch. 96-98 had them. If the switch is open and the compressor is not pretty hot, the switch is faulty. Just connect the two wires together and bypass the switch.
ECU still thinks its an automatic (5MT swap)
Wayback replied to Ibreakstuff's topic in Old Gen.: 80's GL/DL/XT/Loyales...
For an AT SPFI, ECU pin 32 is grounded. To make it an MT, you need to cut that wire. It's a black/red on the largest of the 3 ECU connectors, second from one end between a brown and a light green.
