avk
Everything posted by avk
For calipers that float on rubber sleeves (boots) over the pins: I believe one reason they seize is that the bores for the sleeves in the caliper body rust on the inside, squeezing the boot inwards against the pin. The countermeasure is to remove the boot from the hole (not always done, because there's no movement at that interface), remove the rust, and apply grease. That is, the boot needs to be greased both inside and outside, even though the sliding happens only on the inside. One suitable tool is Dremel with a drum attachment, which is what pamike likely refers to. Machining tolerances and choice of materials may also play a role. The very simple Kelsey-Hayes calipers on my minivan (sliding on two identical boots) passed the "move by hand" test every time I checked.
I replaced valve cover gaskets and grommets on a '95 2.2 l engine with 114,800 miles, and found just one of the rocker bolts to be a little loose. I checked them all with a wrench set at 100 inch*lb (8.33 ft*lb), and the rear, upper bolt on the right-hand side did turn a small amount. By the way, the Fel-Pro set I was using came with blue gaskets (their standard color for "PermaDry" line), and marked "Made in Japan". So now the car has blue JDM valve cover gaskets.
Hood question
avk replied to tidd1340's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
A Legacy Outback? No. Purty color though. -
The part number for the older bolt is 800213030, and the newer one is 12369AA011. I'd be wary about tightening an older bolt to 130 lb*ft, especially when re-using (although some of the much more experienced folks did so with no ill effects). Might be a good idea to get a new bolt. It's no less important than all the other numerous parts being replaced, and costs only $5 or so. Get a new Woodruff key, too.
Just a comment on the trade-in offer. To me (in NJ) it sounds like a good deal, comparable to what you would receive from a private party. KBB is nonsense. But it sounds like they were hugely overpricing the Forester. I recently bought a '06 Tribeca for the wife, after giving the Impreza to the son (time flies like a banana).
