highvolumn2001
About highvolumn2001
  • Birthday 03/11/1953
  • Location
    princeton,nj
  • Interests
    musician
  • Occupation
    building/fire/housing inspector
  • Biography
    I love my wife Jan. WEe are married 34 years. Our son James and grandson Dan are treasures in our lives
  • Vehicles
    02 Outback limited
highvolumn2001's Achievements
Newbie
Newbie (1/11)
0
  1. The problem could be a combination of the rubber fuel hoses loose at their nipples or cracked. They should be tightened. The prv valve may also need to be changed. I went through this a number of times last year and then last night. I hope it is hoses only this time.
  2. I am experiencing the same from the hosing towards the fuel injector in my 01 Outback. I tightened the clamps and that worked temporarily. Upon analysis from my mechanic they could not find anything. The condition started when I filled the gas tank to the brim You could try releving the gas cap. I read about vapor trap as a possible cause. I checked the air filter and that area had no residual effects. No obvious gas spill markings were observed in the engine compartment. Right now I am using Gumout fuel injector cleaner. If this problem continues I plan to contact Subaru direct If one of their people reads this we both would appreciate a solution. Gas smell and or leakage is big time worry. Their US corporate facility is located in Cherry Hill, NJ. If you have some luck pass it on Philo from NJ FYI If you ever have a major head gasket problem Subaru owes up for that and will compensate when you submit your records and contact their excellent staff. Subaru brake systems do suck
  3. my 01 outback has a wobble in the steering column over 65mph. New rotors and brake job done, rotation with good (less than 12000) mile rear tires with balance procedure performed. Condition still present . Car had no vehicular accidents, driven by my wife, maintained regularily. Any ideas or similar experience. NJ area
