Dr.Outback
About Dr.Outback
- Birthday 08/12/1983
Contact Methods
Website URL
http://www.geocities.com/droutback
Location
Pennsylvania
Interests
Subaru's, Computers, anything with an engine.
Occupation
Student/Mechanic
Dr.Outback's Achievements
Advanced Member (3/11)
10
'68 Microvan on Craigs List
Dr.Outback replied to Dr.Outback's topic in Historic Subaru Forum: 50's thru 70's
Since I wasn't selling it, and it something so rare and special, I thought it would be best discussed in this forum. I did email the owner and suggest that he post it for sale in the marketplace here. Craigs List is so hard to search on because it seems you have to search city by city. Instead of just searching the whole board. So when I found this, I thought someone here would want it. -
Been a long time since I've posted here. Been through a few Subaru's and now have a '07 300C. Started searching for a Suby on Craigs List and found this! http://philadelphia.craigslist.org/car/730679291.html
Having uneven tire wear between axles, is like making the car drive in a circle for thousands of miles. The diff gears are not meant to take that type of abuse. It would happen eventually to a front drive vehicle if driven long enough and with a substantial amount of diameter difference between the tires. Google differentials and read up on them.
To swap a WRX short throw into a '93 Legacy, all you need is the joint between the linkage and the shift fork on the tranny. I forget the part number. Now I can't be sure for your year because the Impreza and Legacy were a little less related then in '93. But there's a pretty good chance it'll swap. But it won't shorten the range. So why swap them? If you have bad bushings, just replace and that will make the shifter much less sloppy.
DSC is BMW's stability control integrated with traction control. You don't need traction control with AWD. Traction control is a Band-Aid so they don't have to make the car AWD. Stability control, though, is a nice feature even on an AWD car. And Subaru's VDC is one of the best, even if it reigns you in early making it a little to over-protective. Subaru needs to offer it as standard, but with a defeat switch. Unfortunetley, some auto makers are using stability control to cover up bad chassis design. Case in point, the Mitsubishi Montero. It flipped up during Consumer Reports accident avoidence lane change, but didn't when equipped with stability control.
What you have to remember when comparing a Subaru to a same year car of another make is that Subaru has a 5 year design cycle. Honda and Toyota have only recently switched to a 5 year cycle. They used to be 4 years. So sometimes Subaru's models get lost in the middle. They are designed to meet or exceed the competion when they debut. Think of the '00 Legacy compared to the ancient '00 Accord, or the equally ancient '00 Camry. The '00-'04 Legacy was more on par, in some peoples books, with those models then with the '02 Camry or '03 Accord. Subaru will probably redesign the Forester in '08 which will put it ahead of the RAV, but then 2 years after the new Forester debuts, a new RAV will, and start the cycle again.
The reason the headlights were going out on the '05 was because the bulbs were the wrong hour life. My dad just bought a new '06 Outback and the instrument panel lights are always on. I just drive with the headlights on all the time so I don't forget to turn them on. I've seen people driving when it's completely dark with no headlights on. There were shopping mall lights that were lighting the road, so I guess they thought there headlights were on.
Grounding kits are good for reducing ground resistance thereby alowing lights to work more efficiently. But they won't increase HP unless you have a high alternator draw caused by extremely high ground resistance. Performance chips are risky from no-name companies, and will void a new cars warranty. Plus they could cause poor running under certain situations if they are not mapped well. A high flow muffler might reduce exhaust resistance thereby increasing high rpm power output on a normally aspirated engine, but they usually won't make a huge difference without an entire exhaust of a larger diameter. With air filters it's better to stick with Genuine OEM. They are not much more then after market filters and provide the best balance of flow versus cleaning ability.
