newbie from washington
Welcome to the Forum. Yes do some searching in the retrofit section. -Clay
questions on my girls 91 LOYALE
I have another question, can I put on legacy front struts and hubs with brakes to the loyale if I change ball joints to legacy ones? Also I was goin to swap over the lift blocks to the legacy struts too. I am installing a 4EAT and wanted to use legacy axles with the front susp setup. Any thoughts Ideas? Thanks Clay
4EAT TCU Questions (96 Legacy Outback)
bratclay replied to Wayne Boncyk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOk I checked codes. It flashed one long then a quick one. So I'm guessing code 11? New up date I got speedo fixed it and gotten pulled outta dash. Still bind so I found where the plug is for FWD took the fuse holder with fuse in it and pluged that in. FWD lite on and very minimum binding. And the trans is shifting through all the gears. I will be bringing it to the show so maybe someone can help. Thanks Clay. And for all your help and advice
Delta Cam roll call
Ok first I need a set for my girls loyale that Im installing a EJ22 from a 95 Legy. Im also using a 4eat 4.444 so I want the torque cams on hers. I can send them to you next week after the show. Hows the turn around time? I will also be doing a set for the 95 Imp ej22 we have that Im going to frankenmotor it. So not sure if Im going tq or HP cams on that one but itll be a few weeks before those ones. Thanks Clay
bratclay replied to Wayne Boncyk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes I have ATF light flash. Drain plug tight and everything ok there.
Coming to WCSS? What are you bringing?
I can also bring a ea82 70K mile motor that runs. I can send video of it running. Its getting pulled for ej22 If anyone is interested let me know before tonight. So I can pull it and bring it. Thanks Clay
parts at WCSS 13
I have an oil pan. I also have a EA82 70K mile motor that is getting pulled out for a ej swap if anyone is interested.
bratclay replied to Wayne Boncyk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes I did swap rearends. Installed a 04 foresterXT 4.444LSD. Yes stock tranny was 4.11. Crazy thing is. Installed tranny low fluid so filled it up. Test drove it had the problem. So I drained fuild completely. Two days later filled it up test drove it, it work fine for a lil bit then went back into limp mode. So I installed the cooler drained sum fluid, filled it back up same problem, limo mode. Oh also I unpluged the battery everytime to reset comp. Note my speedo isn't worked since install.
I have a 95 Legacy Wagon Im parting out before I scrap it. I have airbags, abs sensors, trim pieces, dash,etc. Let me know before tomorrow evening or it will end up scraped. Need gas money for the show. I will bring to the show if anyone wants something. Also I can bring my six lug swap in anyone is interested, we need XT6 rear setup with disc brakes. Going from 6lug to 5x100 5lug using legy front susp. Thanks Clay
bratclay replied to Wayne Boncyk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHello I have been reading this thread. Doing research. I have a 95 Imp L with 2.2L dualport exhaust. OBDII. I installed a 94 JDM Legacy Twin Turbo 4EAT 4.444. I am having the binding issue too. I also have shifting problems. In drive it stays in first. If you shift manually I can go 1st to 2nd hard then 3rd nothing and drive nothing. Any ideas???????? I was thinking that maybe I need a JDM TCU from the same car. Any Ideas? I really appreciate it guys. I need to get it running so we have a way to get to the show. Jamie's loyales tranny just too a s**t. Thanks Clay
Motor Mount and Clutch For ej22/ea82 swap
I just found this Rob, Im glad things are coming along. I have a set of turbo brat front springs I could sell you. Ill be doing the same ej22 swap very soon for my girls loyale. Thanks Clay
Convoy from Portland to WCSS13 (details)
We should be heading over Sat. too. Thanks Clay
WCSS13 Registration is Open!
Ok finally pre regs for the wcss13. This will be our first show. So excited. I love working on subis. I just wish I could bring my brat:mad:
Good Wheeling Shots! Add you favs! (Comment Free Thread)
Just some good trail driving in the today up by MT. ADAMS Jamie out enjoying her Subi Little Creek Crossing I know it ant no hardcore but that will come now that we have a new GC project for our daily driver
Turbo Offroad Brat Build
Thanks, I used 2x2 tubing then welded a 1/2" bar on top. To give me 2 1/2"s of lift plus the RX springs. Yes I just redrilled new holes 1.5"s lower on the mustache bar.
