Suba_GL_87
Everything posted by Suba_GL_87
Troubleshooting video.
Suba_GL_87 replied to Suba_GL_87's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Fuse blown. ???? -
already replaced new fuel pump from last year... so, ill check it out for relay and fuse.. -
1987 Subaru gl FI 4wd ea82 Just drive highway and then shutdown.. I seen the RPM didn't bounds and no pre-light warning on dashboard.. It's bad ECM? Or what. Thanks!
Why fuel pump was on for 3 secs and off..
Suba_GL_87 replied to Suba_GL_87's topic in Subaru Retrofitting
Yes. When I starting the cranking... It's nothin to running.. But when I turn on key.. It was fuel hose was just flow a 3 secs and stop.. (not really good pressure, btw) -400 posts - -
But should be fuel pump all the time?? No gas into engine..just 3 secs and gas got killed it. -
Why fuel pump was on for 3 secs and then off.. When I turn key on and fuel pump was buzz and stop for 3 secs. i was replaced ele. Fuel pump than carb pump. Everything is good running when I put starting fluid. 87 Subaru gl ea82 carb manual. Came in ej22 from Legacy 91' manual.
howdy; 1987 Subaru GL FI 1.8 SOCH; when running and driving around in town was great--- but when more than 3,000-4,000RPM with half throttle. pretty slipper but when full throttle became smoothly when up the any hill. fuel filter or fuel injection poor? or what?
hey! this car is 1987 Subaru gl carb 1.8L sohc. was everything went good and hardness wire too. was running but only 3-5 sec and shut down. fuel pump not really good pressure. yes, did replaced elec. fuel pump (Bosch) also replaced tube fuel line. don't remmer what size of tube. also was good sparking and fuel injection good. any advised how to good pressure tube or maybe wrong installed fuel tube line? please help! will put more photo coming soon (FUEL LINE)
Holler! 2005 Subaru gt ej25turbo automatic. I need to huge advised... I just need to swap 5 speed tranmisson than automatic. So, I found 5 speed manual.. TY754VBBBA (can fit) Also need to find driveshaft and differential 4.11? But how about hardness conncet manual than automatic? Before I going to project. Thanks!
swap ej22-radiator tig?
will be bent hose.. -
hey! ej22 is running! but upper and lower hose cannot fit to engine from GL's radiator. I have 2 of 1 1/2" adapter pipe for coolant hose. so, it's good idea use tin weld for pipe on steel or alum radiator? any advised! thanks.
