Suba_GL_87
Everything posted by Suba_GL_87
i was replaced oil pan gasket and main shaft rear seal while i was removed automatic transmission. when i was test starting for engine's on and there's badly as pour oil. i found it out there have bad sealant from rear oil pan gasket because i was put on rubber sealant on the both of gasket oil pan.. so, 2nd time same thing removed the automatic transmission and buy other Fel-Pro oil pan gasket. so, i put the sealant under the gasket on the oil pan before install it...BUT there still leaky like a dripping... so, i just had a removed the transmission for my three times and tell me... please tell me any advised for right way for replaced oil pan gasket OR just use the sealant on it without gasket...that's what Subaru's technology said? also i just buy new inch pound torque.
blowing smoke... oh come on...
Suba_GL_87 replied to maozebong's topic in Old Gen.: 80's GL/DL/XT/Loyales...
valve guides and or rings is worn out... try check compression tester. -
someone people who dont have a engine hoist for Ej20 and Ej25 etc... so, im going tech you for replaced oil pan gasket... *only you need two mini floor jack lever and one of 3 ton jack hydraulic floor. *just removed four bolts between on the engine and automatic and get a out with the crow bar...replaced rear's main shift seal and oil pan gasket. put on the trans-axle for the jack, removed transmission and dont forget input seal ring. and do removed oil pan gasket use the cut off the board wood with two mini jack floor make you easy move and carries. :cool: huge Semi-automatic (3-foot long than EJ25's transmission) yep, we did try 2nd time for replace oil pan gasket in 3 days.
Loyale looses power and stalls on steep hills
Suba_GL_87 replied to MexiLoyale's topic in Old Gen.: 80's GL/DL/XT/Loyales...
!!!???!!! trobleshooting.
Suba_GL_87 replied to Suba_GL_87's topic in Old Gen.: 80's GL/DL/XT/Loyales...
yes, i did 360* for inner belt and i did other 360* for outter belt. i think i need to make be perfectly on the alignment on the sprocket. i did put pump into the lasher adjuster before install...it's very soft than old harder.. -
need a really perfectly alignment from inner and outer timing belt? -
hello, my outback running is pretty good and everything is fine. my miles said 240K... sometime when i tired to starter like a stalling when im waiting for couple min later get turn on.. mostly of i turn on for often. but sometime problem starter wont get turn on, u know? new battery, wire, sparks... (need new coil or what?)
i have a 87 EA82 OCH with FI 4wd(3.900)....i've been rebuilding gasket kits. *Headgasket...i did 3 step torque from Hayne book. from the beck gasket. *Timing belt...i did follow the internet *new; spark, battery, lasher, rocker-arm, manifold gasket. *wire, rotor, cup and alternator is new from couple years ago. ~~~coil, distributor, starter motor and valve is older but should be fine? check out my recently video if you know what sound is? so,tell me whats wrong? i did put jumper cable, check the sparking. seem gas into??
Is a Subaru 360 van useful ?
Suba_GL_87 replied to 2stroketurbo's topic in Historic Subaru Forum: 50's thru 70's
YAH! Oregonians! NICE 360 van, very impression. -
when i was buy new battery and driving for couple days. One day; i drove and notice that ABS 'on' into the dashboard for no reason...Also there already 4 times flash as quickly on the dashboard too? so, i going to pull over and turn off the engine. and then i tried turn on the engine there's WONT start like a death.. there's have a low dim light on the dashboard...(look like low battery) but i already replaced new battery.?! so, i use jump cable on my new battery box, dashboard's light is brighter and there no ABS on. BUT...when i was take off and driving to back home and got problem starter, wont running, still there low dim light on the dashboard like a nothing?! should i replace alternator? Really, i was testing alternator was passed RIGHT BEFORE old battery?
