Suba_GL_87
Everything posted by Suba_GL_87
  1. ive a problem with my electronic flashing light on my window gauge (rpm, mph, oil level, temp level and battery level), you know what i mean? when i start it running and there have a flash light (look like a alarm flash) on my window gauge with ABS light on also there wont work on mph and rpm...only show the gauge for temp control. Ive been try removed some fuse but still there flashing light. but...i don't have any key remove. how to stop flashing and try turn on the mph, rpm, oil level back... AND turn off ABS too.
  2. why lasher adjuster so hard when I pressing, on my ea82? i did put oil pump into lasher but its still hard to pressing (pump)
  3. just replaced gasket and wheel bearing on power steering pump...
  4. you need repair clutch pressure plate, clutch disc and release bearing. it's would be last longer driving.
  5. i have a 5 or 7 Valve Lash Adjustment. there have a harder like a stuck pressing and I've try put pump oil on it and wont turn soft pressing. thats why my suba ea82 had bad backfire from OCH? so, should i replaced new Valve Lash Adjustment?
  6. try check fuel injection into carb if there's' bad or worn out? or check your AIR FLOW SENSORS or maybe Piston Ring worn out? dose your muffler black smog problem? how many miles your suba wagon?
  7. $ around 10 dollar for new gasket...should be fine as soon possable. will cuase save mpg..btw.
  8. i did put the right of the fuel filters hose (in & out) i try running but it just shut down...with during "oil temp" flash. what u mean cross the fuel lines??
  9. actually.. i was replace new fuel filter and somehow my wagon wont running as last.. i did waiting for 5 min running but still no good. when i was start it like a 10 sec later shut down...with oil temp flash.
  10. exactly... i've been trying driving for short but RPM was high became lower to shut down... ive been turn over again but shut down... whats its? :-\
  11. double check-- 1 step 22 ft lb 2 step 42 ft lb 3-9 step 51 ft lb and re torque?
  12. my girlfriends car is Subaru Outback 96' EJ25 ive been try starting became fire up but somehow shut down with during (temp oil light flashing)? thats mean need repair new oil or what?
  13. got ya, thank alot! ill do re-torque it on this week.
  14. thats cam-lobe master...? yea, i know about 1-9 steps follow of head gasket's bolts..
  15. I HAVE A EA-82 ON 1987 SUBARU GL WAGON 4WD. Tell me how much foot-pound torque steps 9 bolts on the cycle master blots..?? I would like to perfectly for improved horsepower...u know? Message here for list steps for nine bolts for ft lb torque.. I have a beck/arnley head gasket...(should i re-torque or not?)
  16. tell me how much ft lb on your step 9 bolts torque? did you perfectly for ft lb?
  17. there have a crack of valve/cycle block, i don't know if it's normal or no good? let me know. it's EA82. thanks
  18. ok... only you need repair is Idle Air Control (IAC) Valve, Pressure Damper, Pressure Regulator, Carburetor Choke Pull Off and Gasket. will improved economy fuel. ya, it's alot cost for parts but worth for save gas. my old mpg was 28 mpg...after rebuilding and repair parts..is 36MPG.
