Suba_GL_87
Everything posted by Suba_GL_87
should i put rubber seal glue on the head cycle gasket? because of i was put pretty alot on the head cycle gasket and there have a flood coolant by pinion and spark plug. because of wont fire it....:-\ im wonder if torque on the head cycle bolt after 3 step is 45-50FT lb? not over-tight?
seroius issue! Wire Elec. Connectors
Suba_GL_87 replied to Suba_GL_87's topic in Old Gen.: 80's GL/DL/XT/Loyales...
everything is good! but i don't know where brown wire coming from!:-\ -
which one wire? you mean- black and yellow to negative terminal? u have any know abt start motor connectors and brown wire? sorry i dont get it. -
Suba_GL_87 posted a topic in Old Gen.: 80's GL/DL/XT/Loyales...
Hello NorthernWestern!:-\ i have a few problem...i was take out the engine of EA82 from my wagon and do rebuilding. Somehow a brown wire just snap out, but i don't know where put connect on it because of my starter switch is not on the electronic even start it too. I'm confused wire which to connect. i need your photo for ** Starter Motor connect which one right ** two wire (yellow/black wire to battery block?) ** (brown wire I'm unknow where that from) HERE IS MY PHOTOS that what i have a serious issue! HELP ME. Black/Yellow Wire to battery negative? or not? that's where i found it and don't know where that from. while i was take out from engine EA82. so, where that coming from? IF you have a EA82 87' Subaru GL wagon--Check on your engine and take photo or explain to me. thats only i need to know before road trip.... -
Good Wheeling Shots! Add you favs! (Comment Free Thread)
Suba_GL_87 replied to one eye's topic in Off Road
Summer 2009 (Crater Lake, Ore) 87' Suba GL Wagon. -
how much limted weight for tow boat.
nice work & weather too :cool: i can do design this..it's pretty easy cuz i can find the junk yard, u know? thank for photo. -
can u send me photo for your rear bumper look like? if so, i could make it. -
where to EGR Vacuum from hose to 87' EA82
everthing is good! thank you for try photo..there is do good! -
Everyone! thank you 987687 for photo... this is SAME exactly my boat but no window becuz of crack. but light blue. im wonder how much weight those boat, what kind hitch bar w 1 7/8 hitch-ball. tell me a suggest for safety tow a boat on my wagon gl 87' thank you! -
no, it's fiberglass. boat made from 1973. yes just one axle -
which one kind hitch bar for on my subaru wagon gl on it? boat like a under 2,000lb... -
well, my boat look like under 2,000LB. -
alright. but i dont have any hitch bar...i need to know what kind hitch model for my wagon gl 87' -
1 7/8 ball -
i have a good boat 13' with 15hp but i dont know how much weight my boat. look like under a ton. im wonder what kind for good hitch bar on my 87' suba wagon EA82? so, i can buy for new hitch bar. -
milky coolant with a recently rebuilt engine
Suba_GL_87 replied to slow be's topic in Old Gen.: 80's GL/DL/XT/Loyales...
There have a 9 bolts from on the head cycle for must right kind torque ft lb . for replace head gasket; First 1st on the middle bolt do on 21-25 ft lb, 2nd on the top of right and by the middle blot do on 42-45 ft lb, 3rd on the top of left by and middle blot do on 48-51 ft lb, 4th on the below of right corner blot do on the 80-85 ft lb, 5th on the below of left corner do on the 80-85 ft lb, 6th on the top of left corner blot do on same 80-85 ft lb, 7th on the top right corner blot do on the other same 80-85 ft lb, 8th on the middle right blot do on the 80-85 ft lb and last of 9th on the left blot do same and same the 80-85 ft lb. that wont be get blown head cycle / gasket and COOLANT. hopefully you understand? -
How much tight on timing belt?
10-18ft/lbs, oka. im plan for for it. my timing belt is tight as fair. it's all good. -
thats what i thought so. thank for tips. your best Cruz. -
thats good photo but it's hard to understand cuz it's too close. would you don't mind zoom out and more clear. which one right on the hose. -
just put whole upper of the tensioner make a belt tightly? not a middle on the bolts tensioner make a fair tight? -
I WAS REPLACED FOR NEW TIMIING BELT. I WONDER IF THATS OKA IF TIGHTY ON THE TIMING BELT (LIKE AS ALTERNATOR BELT) OR ALITTLE LOSE TIMING BELT? BECAUSE I DONT KNOW HOW MUCH TIGHT? LET ME KNOW AS SOON. GO NothernWestern!
word, im very pleasant for it. im forward of you. how come your brake fluid problem? tell me how much you been try fixing? -
anyone who like to photo on your Manifold EA82? i need to know which right for hose connect by EGR Vacuum... -
check anything the hose, even small hose (near carb & water pump) without leaky from coolant. maybe you did over-tight hose with steel clamp cause leaky? there have a badly leaky oil?
