Suba_GL_87
Everything posted by Suba_GL_87
  1. i need anyone who like to picture on the EGR Vacuum hose on your EA82 1987'. because i was confused which connect, TWO of the EGR Vacuum hose to carb Hitachi? I was take off and rebuilding EA82 motor and carb but somehow i forgot which one hose connect from EGR Vacuum? i need you send me a photo on the message as soon. here is photo what look like a EGR vacuum. thanks!
  2. haha, where i can find svx transmisson? it's hard to find it. my suba tanny is 4.44 gear ratio...
  3. i almost forgot put new Fuel Injection. my old fuel injection is very old, rusty and ruin out. that's would be helpfully when get new fuel injection! im going plan buy on this June. hopefully will get more than 34 MPG i could help you if you know where is fuel injection from?
  4. AH! i forgot repair new fuel injection on EA82. i should buy as soon. haha, those outback wagon, im not inserting of it. but that's odd design like as future culture.
  5. haha, i dont want to get GEO. i rather on wagon w 4wd. lmao.
  6. what kind of aerodynamics' fit on my subaru wagon 87'? i'm inserting for it..
  7. only max to 35MPG ON ea82? tell me what kind parts for improved mpg? i can do replace some new parts as soon possible. :cool:
  8. Can do redrill on white soke trailer for make of my Hub Wheel 4 Lugs on subaru GL?
  9. NorthernWestern! i need help find right kinds wheel of 14 inch plus 4 lugs. I've been looking but there wrong fit of lugs on my Subaru GL wagon. please let on message for whats kind wheel of 14inch or 15inch. thanks!
  10. Fuel Pump will get high mpg? if so, whats kind of model?
  11. no air filter only have a carb with filter. -Weber carb 32/34. useful replace new carb filter every 6 monthly. yea, i need new Catalytic Converter, it's could improved mpg?
  12. Holler NorthernWestern; my suba is 87' wagon 5speed shift and EA82. my best high is MPG 32 and over 450 miles by 14Gal. but i need to know what else parts for improved mpg?? So far; i was install for improved mpg. *Oxygen Sensor, BOSH. *Weber Carb 32/34. *Fuel Filter, FRAM. *Spark Plug, NGK G-power. *Spark Plug wire, NKG. *Band tires 34PSI for summer & 32PSI for Winter. *5-30W oil. (only) *No ARCO gas station. *No leaky oil on the motor. *Check no crack/leaky hose on the motor. someone or everyone said that, try to install for new improved MPG- Fuel Pump (if that would be work?), Distributor (it's make a sense but alot of $), and what else, humm?? come on, bring on for improved mpg on old Subaru!
  13. anyone who can find the link for code transmission? i need to know as soon. for order parts. because my transmission come out and waiting for code. this is Subaru GL 1987, EA82, 4WD. thanks!
  14. already have a friends who help me for put new head gasket. yea, there have a suba manual book of wagon 87 1800. thanks!
  15. my car is subaru gl 87' 1.8L. my wagon have badly oil leak from head gasket and there's muddy oil when i parking lots. those made me headache buy new oil pint turn over again. im fed-up and buy new head gasket. anyways; when i was remove a valve cover and there have a cam-lobe. so, i try remove a block of the cam-lobe. it's hard to remove also stuck. But somehow the cam-lobe's valve's a part fell down made me very anxious (look like a *rectangle with sliver there a hole* for support valve to cam-lobe) i don't know what called it. so, i did struggle a little longer try to put back away but helpfully i put some sticky grease on valve between cam-lobe and go back together. so, i've been looking around internet and try think how to replace head gasket. :banghead: feedback me!
  16. my car is subaru gl 87' 1.8L. my wagon have badly oil leak from head gasket and there's muddy oil when i parking lots. those made me headache buy new oil pint turn over again. im fed-up and buy new head gasket. anyways; when i was remove a valve cover and there have a cam-lobe. so, i try remove a block of the cam-lobe. it's hard to remove also stuck. But somehow the cam-lobe's valve's a part fell down made me very anxious (look like a *rectangle with sliver there a hole* for support valve to cam-lobe) i don't know what called it. so, i did struggle a little longer try to put back away but helpfully i put some sticky grease on valve between cam-lobe and go back together. so, i've been looking around internet and try think how to replace head gasket. feedback me!
  17. pretty rip-off try website- http://www.partstrain.com/ there have very good price and reasonable. ive been buy online there no problem and good shipping as fast than i expect it! i was order 4 shuts (front and rear) of air/gas KYB cost $181 plus shipping.
  18. you will find it out when u got a snow. I've been driving on snowing with 4wd becuase i live near mountain from Oregon. anyways, if not use on 4WD then will going pretty slip off and will for sure get going slow down because of wagon pretty light weight.:-\ what's your plan for project on ur wagon?
