Suba_GL_87
Everything posted by Suba_GL_87
I don't remmer which is fuse is in the hood (black fuse box) depend of year. Or under the dashboard and check if fuse is blown. 15AMP. 1 lucky Texans- yes, he's right.. you are hearing. I'm hearing impaired. Haha. Fuel pump is where inside your wagon behind the rear passager seats(couch). You just have to alittle remove the carpet and see the mental cover and hear if said "Hummm" when key on, no running. if not.. It's failure of fuel pump.
3rd gear and won't move.
Suba_GL_87 replied to Suba_GL_87's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Actually was pull out the engine. -
1984 Subaru gl fwd. After repair clutch kits and rear seal.... When test driving, it was good on 1, 2, 4, 5 and reverse. But 3rd gear won't go, and can hear gear noise when I tried to push hard. Anything else idea? I don't think if it's bad trannmission. Cuz was work on 3rd gear when before repair clutch.
87' FI ea82 I have everything oil pump for rebuilding bolts/seal/gasket kits.. Should I put RTV sealant before installed? What torque foot lb?
Oil out to air filter?
Thank milesfox! Pcv were old vavle and lose. Thump up! -
Oil on the air filter and drip of the them.. Oil gone around 3 pints oil.. It's oil pump bad cuz was low psi while driving..?
2004 Subaru outback base 2.5L Here's this photo. I was use plier for removed the hose but somehow damage leaky. So, I was went to Subaru dealership cost me $80 for new hose. But I'm not going pay for that.. I'm asked if can use regular common fuel injection hose with metal clamp.. Thats will be work for that? Thanks
