Suba_GL_87
Everything posted by Suba_GL_87
This YouTube May help you...
Need to know which wires colors hook to ej22
Suba_GL_87 replied to Suba_GL_87's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Which hook up fuel pump wire on fuse box or fuel pump control relay?Yes, of course.. I did put on ground wire. -
Which relay switch? Photo.
Thanks. I just need to know what's relay switch of four them. Before to ej22 hardness hook up. -
How about top hose?
Oh ok. I thought its ignition coil... but Where's tachometer by the ignition coil? -
88 Subaru GL EA82 Plug Wires
Suba_GL_87 replied to stillmarykay's topic in Old Gen.: 80's GL/DL/XT/Loyales...
1+ -
Need help finding 4" lift
Suba_GL_87 replied to redloyale's topic in Old Gen.: 80's GL/DL/XT/Loyales...
+1 same thing... Hardness ej22. -
Can use flex hose?
82 Subaru driver side mirror?
Anyone idea?? -
I'm not sure which is relay switch. Fuel pump relay, ignition relay, kick down relay. Number 2 photo; it's ignition coil? Let me know. Thanks
Like to photo... Just like to get idea. Thanks
What website?? -
Fel pro way better.
Email saucecuz@gmail.con -
Anyone idea for universal mirror? -
I cannot find any part for driver side mirror. Like to know what number part can fit from any mirror of universal. Thanks.
I did already swap ej22 egine into GL. But I have gl radiator but need to know what shape to look like upper and lower hose fix to ej22 Thanks.
Professional.. O_o
Low pressure oil pump.
Yeah, I was test oil pump pressure test was good psi. But I don't know why still rough idle and pretty low rpm before die. I was put adjuster more fuel/mixture on crab/FI for avoid to low rpm... -
Actually already installed new timing belt kits & oil pump gasket. You mean camshaft sprocket's tooth off?
