Tonyp5143
Everything posted by Tonyp5143
gbhrps, Thanks for the AWESOME detailed response! I have never removed a headliner but with you info I think I can do it. Do you think that there will be bare metal under the roof for me to stick these sound deadener panels from Dynomat? While I am tighening the loose roof rack I want to make the car a littl quieter. thanks again! TOny P
I do not llike the wind noise I hear insode my 2001 Forester with the roof basket mounted while driving on the highway. I have some sound deadening material that I would like to install under the roof panel. Also, I have a roof rail that is a little loose that I would like to tighten. Anyone removed the headliner and would like to share some tips? Thanks, Tony P
I have a 1985 Brat, 120,xxx miles. The 3 speed Auto Tranny is slipping bad on the 2nd to 3rd shift. I have another 3 speed tranny to put in it. I am told that it is good, sure hope so! I would REALLY appreciate any tips as to the order of removing and replacing tranny. Should I remove engine and radiator? I have been wanting to replace the auto with a hi/lo manual preferably a 5 speed, but financially, I cannot make that happen. I think I am gonna replace this auto tranny and the motor / tranny mounts and sell my Brat. I just do not like owning a 3 speed auto Brat! I'd appreciate any suggestions! Thanks again, Tony P Monroe, NC
I need to replace my 3 speed auto tranny and all other related parts, pedals, shifters, rear axle,.....etc in my 1985 Brat with a manual tranny. Can I use these parts from a Gen 1 Brat? thanks, Tony P
My 85 Brat just turned 121,000 miles. I have a a rear engine mount or tranny mount going bad. When Brat is in reverse, there is a bumping sound upon throttle application. I ordered a new mount from Rock Auto that is supposed to be for 3 AT Brat. But the mount I received looks nothing like what is on my Brat. Anybody replaced this mount before? Where did you buy the mount Any suggestions? I REALLY wish I had a 4 or a 5 speed! Thanks, Tony P
I have a new rebuild kit for the oil pump if you cannot find one locally. Tony p New Salem, NC
Fuel problem ? HELP!!!!!
Tonyp5143 replied to murderwagon's topic in Old Gen.: 80's GL/DL/XT/Loyales...
What year / model Suby are you inquiring about? Tony P -
EGR light on after installing Weber on 1985 Brat
Tonyp5143 replied to Tonyp5143's topic in Old Gen.: 80's GL/DL/XT/Loyales...
So I will reset the light. Do I need to recconnect the Vac lines to the EGR stuff, the BRAT runs great as is. What about the Emissions Canister, do I need to somehow connect it? The Fuel Return line is plugged at the moment, is that a problem?/ Thanks, Tony p -
Where can I find "Camerons' Diagram??? thanks, Tony P
Cannot find Weber instal write up
I am still not sure about the fuel return line, and all of the other evap lines, vac ports, etc on my E81.... Tony P -
This guy lives an hour or so from me. He builds E71 and E81 engines for experimental aircraft applications. He also rebuilds the ND Distributors with a GM "horse shoe module, which is a cheap alternative to the stock replacement module when it goes out. His company is called Ram Performance. http://charlotte.craigslist.org/pts/2984036963.html Tony p
Hey guys, I am going to instal a new Weber 32/36 on my 1985 brat today. I have searched and cannot find a write up on this. I am not sure what to do with the fuel return line and all this other extra plumbing, and vac lines.I have a 1985 Brat with 3AT. Thanks, Tony P
Guys I am seriously thinking about buying a 1982 Brat DL parts truck and installing the 4 speed hi / lo tranny in this parts truck in my 1985 Brat GL which currently has a 3 seed auto (which I really dislike). I ASSUME that there is nothing different on a Auto tranny Brat that would prevent me from installing all of the manual tranny parts. I know I will need to do a lot of work, clutch pedal, console shifters, front and rear diffs, tranny,....etc... I am tired of the poor performance with the Auto tranny. My 1985 GL Brat gets 22 mpg around town and about 25-26 on the hwy. I have been told that with the 4 speed I can get 30-32 mpg, Is that realistic? I am also going to install a Weber 32/36 or maybe a slightly larger Weber. And after the work is done, I can make a little money selling my 3 speed that works fine, and all of the extra parts from this parts truck ( with the rusty bed) to earn a little extra money. I would really appreciate any opinions from you guys! thanks, Tony P
Tranny Crossmember Question
Tonyp5143 replied to Sonicfrog's topic in Old Gen.: 80's GL/DL/XT/Loyales...
What does IIRC mean? No adjustment of the Modulator affects the shift point. Even tried trans Medic, and changed fluid again using B&M Trick Shift, no change. Is there a band adjustment? Local transmission shop is no help. thanks, Tony p -
Well, I have a 117k original miles on a nice looking rust free Brat, engine is in excellent condition, no oil leaks, very original truck, with the original 3 spd. tranny. First problem, Even with wide open throttle, it shifts into second gear at 12 mph, which KILLS acceleration and I am sure puts an extra load on the engine. At anything less than WOT, it shifts into 2nd gear at 8 - 10 mph. A local Subaru mechanic replaced the modulator with an adjustable one, and flushed tranny fluid , and the 1 to 2 shift is still no later than 12 mph. And the performance and fuel mileage really sucks compared to a manual tranny. Other than that, the 3 speed is great! thanks, Tony p -
Shawn, So, are you saying that if I buy a 84 Brat with 4 spd hi/lo, that I will have EVERYTHIN I need to replace the 3 spd auto in my 85 Brat? I have had two people tell me that it will not work without major fabrication.?? thanks, Tony p -
Another question. I was told that If I bought a 1984 4speed / Dual range and rear diff that this will NOT bolt up to my 1985 3speed Auto brat. I was told that it just will not work. Does not sound right. Is that true? I can buy a complete 1984 Brat with 4 speed Hi / lo really cheap. Why would this NOt work? thanks, Tony p -
Jerry, Do you have a Kit to replace my 3 speed Auto tranny in my 1985 Brat with a 5 speed? If so, what is involved? I guess I will need to find a 5 speed tranny, will any 80's 5 speed work? And I will need a clutch pedal? Price? Any fabrication on my part? thanks, Tony p -
I have an 85 Brat. My A/c gets down to 40 F on a 93 F day. But, cold air only comes out of the center vent. With just a VERY little bit of cold air out of the other vents. I took the fan out and cleaned the blades, and cleaned out the electric motor. I have real good quiet fan speed, just almost ALL of the air comes out the middle vent ! Tony P
