Everything posted by derfster
I had a fuse in the car when this happend . I kinda thought it was this but just wanted a second opinion . the car didnt run when i got it it, has a jdm engine ad runs like a rocket after an extencive cleaning of the entire engine cat converters and engine bay. You wouldnt beleve what a clean engine will do. thanks ill order a duty c - solenoid .
got my subie runing last week. When i wired the crank sensor got it backwards .... Some times it can be the most simple things .now to apalogise to the company i got my motor from for the cusing and hell raising i put on them . but i will addmit i was wrong but any ways it running and got a lot of power its freky fast didnt expect that. thanks to all ...
I checked a lot of stuff today, I puled my engine just to check a few things. Also the two green plugs were pluged in now it dosent click and carry on. Every thing is apart right now but its going back together to do more testing from ecu .Iim actualy working on an 86 subaru automatic to manule swap and its hard to go back and forth between cars . Im puting my gt back together knoing that it is definetley an electrical issue . and am confident that with the help of everyone on this forum i can get my subie back on the road. So thanks to all...
Not sure when the jdm engine ran last . I had to swap the harness from the old car bucause the company that i recieved my engine from cut the harness in two spots , Uncalled for in my book especialy when there are two or three places where they just unplug. Also when i swaped harnesses, My crank sensor and knock sensor wires were cracked so i cut them and used the ends from the jdm harness and put them back where they were. Is it possable that something could be wrong there, like what color wire goes where i might have it backwards .
I bought a 97 lagacy gt wagon put a jdm engine ej 25 d got fuel got fire . my fuel pump comes on and then go's off again.when fuel pump comes on under the hood i can hear a hissing sound There are silinoids clicking under the hood when i turn the key on and my check engine light flashes too. I also put an obd code reader on it and it shows ( p 1100 p 1101 p 1120 p 1121 p 1540 p 130 p 136 p p 500 I know what the codes are but why are there so many codes.Would that keep my car from running, could this mean that my ecu is bad or needes to be reset . also could the factory car locking system keep the car from running i have reset it but might still keep car from running. also took off catalitic converter it was dirty. I know you can start a car with out catalic converter on but im going to replace it and the o2 sensors .This has got to be something simple
fuel pressure regulator is on the passanger side i think , Thats where the hissing or gurgleing sound is comming from when key is on I can heare the fuel pump turn on but goes off a second later fuel comes out of return line. the car sat for 1 to 1 and a half years but drained all the gas and put fresh in 2 weeks ago with stabil and sea foam .
ive put a jdm engine in my 97 legacy gt wagon and it wont start relays and fuel pump turns on and off with key on check engine flashes on and off . Engine justs turns over and over but trys to run sometimes and wont take fuel im comepletely stumped. i alsoput an obd II reader on it and got the following codes p1100 p1101 p1120 p1121 p1540 p130 p136 p 500
i just recently bought a 97 legacy gt wagon and performed a jdm engine swap. swap went smooth as silk but when i tryed to start it, it cranks over a littile and then dies ive put an obd II conecter on it and shows the following codes p 1100 p 1101 p1120 p 1121 p1540 p130 p136 p500 and the last four are pending ive checked all the sensors but o2 and throtal pos sensor . When you turn the key on fuel pump turns on and off and i can hear sylinoids clicking on and off i used to have hair a mean head of hair before i started this................. help ........
97 legacy gt wagon will not start
derfster posted a topic in Meet n' Greet. Your USMB Welcome Center
7h e l l o o u t t h e r e ..... :slobber: i have a 97 subaru lagacy gt wagon that will not start ive done a jdm engine swap and swaped the intake and such and ive hooked up a obd II diognostic reader to it. shows the following codes p100 p101 p1120 p1121 those are fuel and air metering . also p 1540 idle speed control . P130 thats o2 sensor malfunction bank 1 sensor 1. p 136 o2 sensor malfunction sensor 1 bank 1 p500 speed sensor malfunction . ive checked most of the sencors in the car would this cause the car not to run. well it trys to run but then dies would this be a bad ecm , also is makeing a bunch of clicking noises under the hood and in the cabin of the car.....
